Jacking the C5
Old Jul 27, 2007 | 05:13 PM
WildTurkey's Avatar
WildTurkey
Default Jacking the C5
What is the exact equipment you need to safely jack up a C5 (hydraulic lift, jack stands, wood blocks, C5 lift adapter, etc.). I dont want to spend too much $$$, but want to be safe (and do it right).
Where did you guys get your stuff from - Autozone, etc.?
I'm sure this is covered in another thread, but I couldnt find it. If you have a link, that would be great too.
Old Jul 27, 2007 | 05:33 PM
bilx013's Avatar
bilx013
St. Jude Donor '12
I just got some lifting pucks off flea bay for 23.00. You will definetly need these for a safe lift. I am sure others will chime in as well.
Old Jul 27, 2007 | 05:35 PM
rws.1's Avatar
rws.1
Here is a good link for you... this is how I jack my Vette when I work on it...
http://forums.corvetteforum.com/show...s&forum_id=103
Old Jul 27, 2007 | 06:40 PM
silverbullit99's Avatar
silverbullit99
Make your own lift puck,,,
works well... I keep a spare set in the trunk compartment in case I ever have to get an emergency repair at a garage..
Old Jul 27, 2007 | 07:27 PM
TheDEfan's Avatar
TheDEfan
I use this method. My floor jack won't fit under the car with the pucks.
http://www.z06vette.com/diy_lift.php
Old Jul 27, 2007 | 07:57 PM
jbondfl's Avatar
jbondfl
From: Tampa Bay, Go BUCS!!!Go Rays!!!Go Lightning!!!
St. Jude Donor '12-'13-'14
BMW pucks and a Walmart low profile floor jack.
Old Jul 27, 2007 | 08:20 PM
bioman's Avatar
bioman
Roll up on a couple of 2 x 8 x 12 pieces first......then most low profile jacks will work
To Jacking the C5
