[Z06] royal purple or lucas oil?
I'm goin to do my oil change soon, just want some advice on what oil is better, and most common among corvette owners, which do you recomend thanx
Lot's of good oil & fluids out there.Everyone has a personal preference.
Here's what I do in my 02Z.
Oil:Pennzoil Plat 5w30
Oil Filter:Purolator Pure One PL14006
Trans & Diff:RP
Clutch & Brake:Valvoline Syn Dot 4
I use the same brands in all my rods.No problems.Opinions vary.
\db2
Carolina
Trans & Diff:RP
\db2
Carolina
There are so many synthetic brands out there now.. They are all good. As long as it meets the GM requirements and you reset your DIC after every oil change, then do a change when you get down to 0 oil life remaining you will be fine.. Oils have come a long way. I've never seen an oil related engine failure with any of the synthetic brands
