Help....hatch will not release
Old Aug 2, 2009 | 08:30 PM
bowwow's Avatar
bowwow
Default Help....hatch will not release
A couple days ago, my hatch stopped working. The hatch release on the key fob doesnt open it neither the one on the dash.
Has this ever happened to anyone?
Old Aug 2, 2009 | 08:32 PM
Jet-Jock's Avatar
Jet-Jock
Did you try the manual pull string?
If your vehicle is equipped with a hatch and you have lost
battery power, use the manual release cables to open the
hatch. To access the cables, remove the two access panels
located in the rear of the trunk area. There is one cable
located under each access panel.
Old Aug 2, 2009 | 08:40 PM
bowwow's Avatar
bowwow
I did...the pull strings are the only way I can open it.
Old Aug 2, 2009 | 09:27 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Checked the fuses yet?
To Help....hatch will not release
