[Z06] Please post your stock/bolt on dyno #'s
Old 02-11-2011, 03:08 PM
  #41
Gearhead82
Gearhead82's Avatar
2003 Z06
Vararam, ARH 1 7/8" w/ catted x pipe, GHL Bullets, Tune
Old 02-11-2011, 03:36 PM
  #42
firefighter813x
firefighter813x's Avatar
Y'all are making it really hard for me to decide! A month ago I was set on the 1 7/8 AR but now the OBX/XS Power are tempting.
Old 02-11-2011, 04:22 PM
  #43
GARY2004Z06
Support Corvetteforum!
GARY2004Z06's Avatar
I'm not going to knock anyone else's product; however, comparing dyno graphs does not mean that you will obtain the best performance. All dyno's are different as stated by other members. I can tell you that we put down 532 HP on a ECS's Dynapac and 477 HP on Tune Time's Mustang dyno. (These pulls were corrected and literally made a couple days apart.) You should compare products for fit, finish, price, paper results and most importantly, track results. We can tell you that the FASTEST N/A Vettes all run ARHs.
Robz's 346 C5Z ran 1 7/8" ARHs.
Robz's 388 C5Z runs ARHs.
Our Bolt-On C5Z ran 1 7/8" ARHs.
Our Bolt-On C6Z runs 1 7/8" ARHs.
Fartpipe's Bolt-On C6Z runs 1 7/8" ARHs.
Sebast19x Bolt-On C6Z runs 1 7/8" ARHs.
Just food for thought.
Old 02-11-2011, 04:26 PM
  #44
Toque
Toque's Avatar
Location: Wylie TX --> Less is More, except under the hood !
Bone stock 358/350
Add LG Pro Long Tube Headers with Cat's, Vararam, B&B Bullets, Air Bridge.
After the above I got 390/380.
Add LG G5X1E cam, AFR 205 heads (59cc), UD Pulley, Shanner polished TB, 160 stat,
After the above I got 448/432.
All on the same Dyno at LG's.
Toque
Old 02-11-2011, 05:30 PM
  #45
firefighter813x
True... I should know a lot about being heartbroken by dyno numbers. lol I had a stalled A4 that was horrible on the dyno but quick on the street. Surprisingly I've heard a lot of positive things concerning the OBX headers. I recently had the chance to speak to a former LSx shop owner that we all know of (would rather not disclose) and he STRONGLY suggested the 1 7/8 header for the LSx cars. Brian Tooley @ TEA even said that with the stock 2.00/1.55 valves work well with the bigger primaries and DO NOT lose power on the low end. Even though I have this knowledge, it's tough to justify spending $1400 on headers when my Pacesetters on my Z28 were great. Can we really feel a 5-10hp difference? I probably can't... that money could be spent on the dyno tune! With this same logic, the TSP mild steel ceramic coated headers are an option too. If there were 1 7/8 headers that were made by OBX or TSP I'd already have them.
  #46
firefighter813x
FWIW- Nick @ ARH did have great customer service when I spoke with him.
Old 02-11-2011, 05:34 PM
  #47
firefighter813x
Is this accurate??
http://www.sparktecmotorsports.com/h11113s.html
Old 02-11-2011, 07:29 PM
  #48
Bobtam
Bobtam's Avatar
Default three runs
2003 ZO6
ARH 1 3/4 Headers With cats
Halltech stinger intake
Untuned SAE factored
364 HP 347 Torque
Tuned buy East side performance
Unfactored
404 HP 391 Torque
SAE Factored
390 HP 380 Torque
Tune makes all the difference
Old 02-11-2011, 08:04 PM
  #49
GARY2004Z06
Brian is a great guy who knows his stuff. We went with the 1 7/8" years ago after I spoke with Nick. If we decided to go H/C, the 1 7/8" would be perfect. The 1 7/8" were untested on Bolt-On only LS6 motors. Conventional wisdom said that the larger tubes would lose low end TQ. We felt that they would work and they performed admirably. On the street, low end power was great. On the track, the results speak for themselves. With our goals in mind, we wanted the best we could put together, hence, ARHs. Price should be considered based on your goals but make sure you can live with your decision. Having to make a change later will cost more in the long run.
Good luck with your build.
Old 02-11-2011, 09:00 PM
  #50
firefighter813x
thank you
Old 02-12-2011, 05:34 PM
  #51
Ragresen
Ragresen's Avatar
03 ZO6, double cone intake, Carbon Fiber Speed hump, Stainlessworks 1 7/8 long tube headers with cats and crosspipe, Tune, and the stock Ti exhuast.
SAE corrected 380.9 HP 361.9 ft-lbs
In comparison on other C5's and C5 ZO6's dune on the same dyno I am on the higher end of things for cars with similar mods.
Old 02-12-2011, 06:08 PM
  #52
firefighter813x
Mustang or Dynojet?
Old 02-13-2011, 08:26 PM
  #53
96Smoke-Eater
Cruising
96Smoke-Eater's Avatar
Looking for a good comparison between bone stock '02-'04 Z06's that have been tuned VS bolt on cars with headers, intake, etc
If you do have aftermarket headers, please specify primary size as well. FWIW I will get the 1 7/8 ARH's if I do buy headers.
I might be moving back to CA and if I get a good idea what tuned cars are putting out I may just save my money and not buy long tube headers and avoid smog all together. I've already had a 478whp '98 Z28 would like to keep my '02 C5Z fairly stock.
I got a 72 Stingray, with LS7 in it. It makes 545 hp
Old 02-13-2011, 08:38 PM
  #54
firefighter813x
First off, the only smoke you eat is the rubber from my stock Z in front of your '72. You'd be a god if you had a LS7!
Old 02-13-2011, 08:39 PM
  #55
firefighter813x
Sell your '72 and buy a newer Vette and forget about doing the engine swap. Just an idea...
Yours is a lot cleaner than this... http://www.usedcorvettesforsale.com/...tte-38878.html
Old 02-13-2011, 08:47 PM
  #56
ctusser
ctusser's Avatar
Notice most people say thier numbers are from a low reading dyno or are relatively high in comparison to other similar cars done on the same dyno.
For the record: My car underperforms most other cars with similar mods on most dyno's. I think I may have been the first to say that.
Old 02-13-2011, 08:58 PM
  #57
96Smoke-Eater
Cruising
HECK NO !
Gotta keep them old ones on the road.... There's a million C5's on the road, but U dont see alot of Clean, Chrome Bumpered, C3 Vettes on the road, So, I'll keep it
I cant wait to Drive ur ZO6 though !
To Please post your stock/bolt on dyno #'s
Old 02-13-2011, 09:04 PM
  #58
96Smoke-Eater
Cruising
By the way , How R U list as a senior member and Im listed as a junior member, when I joined 6 months before U ? Do they go by how many times U post ? If thats the case then I understand cause I rarely post anything
Old 02-13-2011, 09:08 PM
  #59
ctusser
ctusser's Avatar
I think it goes on post count. You need to post up more often
Old 02-14-2011, 09:50 AM
  #60
firefighter813x
Taking the Z to get the new tires mounted and balanced right now. I'll drive the '72 and you can drive mine!
Quick Reply: [Z06] Please post your stock/bolt on dyno #'s
