[Z06] What did you do to your Z06 TODAY??
#3461
Don't fear the acceleration of the lightweight clutch
#3462
Well I tried to lower my car today on the stock bolts, read as much as possible and seemed very easy to do. Except both my 2 front bolts were frozen solid, sprayed the **** out of them top and bottom with pb blaster, let them soak for a while and still couldn't budge them. So naturally one of the 10mm heads started to round on mine. So I ended up having to pull the dam leaf spring completely out of the car. 4 hrs later i'm welding a nut to the one bolt so I can get it out of the dam leaf spring. Just turn the bolts they said, it will be easy they said, LOL
#3463
Received 1,261 Likes
#3464
I swapped out my brake pads and rotors for my Carbotech/Centric track setup. I also pulled the radiator out and cleaned the debris out of it for a little better cooling, as well as a flush, for my track day at Barber's Motorsports Park this coming weekend.
Tonight I will put fresh Amsoil Torque Drive fluid in the trans and fresh Amsoil 10W40 oil in it, and she should be ready to go
#3466
600 hp and tq in a c5 is no joke, enough to take out most of the cars you would run into on the street... you can probably start messing around with some bikes now, that's a lot of fun
#3467
be leave it or not with out the bottle it hold its own pretty good too for about 90% of whats around here (471rwhp 414rwtq) i've out ran a lot of cars some bikes too, i turned up my car to run some friends one has a c7z the other a bolton & tuned 13' gt500 with 700+rwhp i'm sure i have the c7z covered but that gt500 it going to be tuff
#3468
Today, I took the dog out for his walk, and drove in the rain. Also bedded in new brake pads, what a difference in feel going from a race pad back to a ceramic.
Mark
Mark
#3470
I did two things today, lowered the car 1 inch on all 4 corners, and installed the light black out kit. 1 inch is about all I can go, or wanna go, it's low enough and I scraped getting up my driveway before the inch lower.
Scotty2000SS (09-21-2016)
#3471
Mark
dylans (09-27-2016)
#3476
Do they just bolt right up? no mods or adjustments ? And when you say what a difference can you explain that in detail.
#3478
They bolt right up - in fact, the DRM's were exactly the same length (at least on the rears) as the OEM's. My Z' is an '03. As you're probably aware, in '04 GM switched to different valving and to a Sach's shock. The '03 was a bit scary on bumpy curves at speed. The DRM's feel much more secure - no discernible wheel hop on rough roads/curves. The rear-end feels much more planted....HTH
#3480
