[Z06] Fast 92mm intake and ls2 throttle body?
How many are running this setup? What all will I need to finish the job? Any problems? And what's the HP gain going fast 92 over ls6 on an ls6 engine?
http://www.toquez06.com/fast.html
Keep in mind your gains won't be as large if you have stock heads/cam.
Just LT's and high flow cats right now. With the fast 92 and 90mm throttle body I plan to add a vararam ram air intake, and than get a tune. Just want to do bolt-ons. Not going to touch the inside of anything for a long time if ever. Want the car to be a fast bolt-on car.
I gained 18rwhp and 12ft/lbs with heads and a cam. It also improved the power curve, allowing the HP to carry through to the 6850rpm rev limiter with no drop off.
skyavonee - awesome link!
I have also been considering doing an intake swap. what kind of gains can you expect with a came only LS6 engine with full exhaust?
Also one thing I might add, now (while swapping intakes) would be a PERFECT time to install an oil pressure sender relocation kit!
