[Z06] Z06 tire inflator kit on ebay
This is not my auction, just posting in case anyone here needs one:
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1843027845
Re: Z06 tire inflator kit on ebay (NewVetteLover)
Cool ... but a plug kit is cheaper
1 Post
Re: Z06 tire inflator kit on ebay (Jackdog)
Jackdog, I think there may be some misinterpretation - my understanding was that it is not recommended to use a plug as a permanent fix, but it should be fine as a temp. Proper repair to maintain the tire's speed rating is an inside patch. (I'm sure someone will correct me if I'm wrong!)
As to whether one uses the goop or a plug, having the compressor will come in pretty handy should you find yourself in a pickle! :eek:
Re: Z06 tire inflator kit on ebay (thevettenet CA)
Your answer coincides exactly with what I was thinking. I could see no reason why you couldn't use a plug for a TEMPORARY fix. Using the "goop" for a quick fix would probably be easier but I can't imagine that stuff working as well as a plug.
Received 1,305 Likes
CI 2-3-4-5-6-7-8-9-10-11-12
Wounded Warrior Escort '11
St. Jude Donor '03 thru '24
NCM Lifetime Member
