[Z06] Let's talk rear end gears
I am asking this specific to the Z06 trans group as my searches seem to have people chiming in with A4 cars, and non-Z06 6MT's that will likely see different results.
The car is not a daily driver, however it is certainly not a track car. I am considering either 3.73's, 3.90's, or 4.10's.
I'm leaning towards the 3.90's as a compromise between too much, and the jump from 3.42's to 3.73's possibly being not enough.
The car as of now is simply a CAI/X pipe combo, but I also has a Nitrous Outlet 100 shot, and plans are for a custom FTI cam/springs pkg, an ATI dampner, and long tubes/X combo.
I'd like to stay in 4th gear through the traps (which with a good tune should be in the lower 120's; maybe 122-124ish) on motor, with a shift into 5th if necessary on bottle.
What are some forum member experiences with rear gear swaps from both a driveability and performance standpoint, and if you had to do it differently would you?
A really good friend of mine did heads/cam, fast, tb, headers x pipe, air intake. Can't remember what it made on the Dano, but he said he was really disappointed with the car. He said it really didn't feel that much stronger after all the upgrades. After all that he then added 410s. He said it was a night and difference once the 410s were installed. With the power upgrades and 410s he said the car was an absolute beast. To time slips however. All seat of the pants. I'd be curious to know how a stock c5z would respond to 410s only.
IMO 3.90`s are perfect. Redline in 4th. is around 130+ I have my limiter set to 6800 which makes it around 136. Drivability is great, have been on many road trips incl Bowling green . Mileage will drop a bit, but who cares? RPM at 80 will be around 2250 in 6th. Do it! you won`t regret it!
Funny, I just posted about my mods for performance in another thread less than 2 minutes ago... lemme cut and paste:
I'm not quite sure if you already have a bottle or if that's part of your plans. You say, "The car is not a daily driver, however it is certainly not a track car.", which gives me the impression that you wanna 'compromise' between the two for both. If that's the case, I would choose either the 4.10's (only) vs. H/C/I as a dichotomous path... one or the other, but for streetable applications, not both, especially on the bottle.
I have no experience here--this is just my WAG, but gears, H/C/I, and a bottle will require both a clutch upgrade and tranny/differential braces. (Everything I remember having read leaves me the impression that your 3-'methods' combination will put tremendous strain on the drivetrain.)
I'd advise that you do some heavy research (reading) on H/C/I combinations in consideration of your final goals for this car, and then talk to 2-3 speed shops to see what they recommend. But...
I've read this complaint about H/C/I combinations several times before; it's why I was leery about speed shops' preferred recommendations vs. my wants; and from previous gear-swap experience in other cars, I knew lower gears would be an absolutely satisfying mod (if not one to finish with). Momo heads, which springs? cam? and what intake?--I was holding off, waiting for Atomic to get the z06 configuration correct when my clutch went out, and at that point I was forced into a financial decision...
I'm content with 4.10's as I wrote. I can't envision the car as a DD with the addition of H/C/I, but NO might be palatable since that isn't always 'on'.
75mph with 4.10's will hover at ~2300rpm; gas dropped from a hand-calculated 27.4mpg to 22.0-24.4mpg... everyone said I'd loose "1-2mpg" (NO ONE said I'd lose "3mpg"), but I can't keep my foot out of it, so I've not seen 25.4 yet. and don't care, neither
I forgot--I think you're right about 3.73's--'everyone says' 3.42 to 3.73 isn't enough.
My mods in chronological order:
LT headers
CAI
4.10 gears
Chuck CoW tune
I decided to go with 4.10's instead of H/C/I because my goal was just to add some usable torque and turn 6th gear into a 'gear', and not "overdrive". The gear installation wasn't cheap; $1800 for the differential alone plus $250 to install it. That included new axle seals. Another reason I chose the gears was because I was already paying for the labor of disassembling the drivetrain (new clutch), and the price of an additional $2G's would be cheaper than the H/C/I (Momo) combination. Gears "alone" would also eliminate any need for me to weigh one shop's recommendation against another's for H/C/I combinations and compatibility.
I am completely pleased with the outcome... the car is 'scary' quick compared to OEM, and I haven't yet had the guts to stomp it from a dig. I'll prolly never do that since this is only a street car and I don't dig at lights. As quick as it is, my curiosity about its' launch capabilities is truly tentative. I don't wanna be in a YouTube video taking a hard left turn as my tires break loose.
I might should have done the 4.10's first (and then I could have skipped the rest [but the CoW tune really helps]), but I didn't wanna pay for the drivetrain labor until the clutch needed replacing.
Everything I've read says 4.10's preclude H/C/I mods later unless you're building a devoted drag car; the lower gearing damn near eliminates 1st-gear traction in a street set up launch and another problem some guys point out is 4th gear (near the end of a 1/4-mile run) runs out early just when you need it.
LT headers
CAI
4.10 gears
Chuck CoW tune
A really good friend of mine did heads/cam, fast, tb, headers x pipe, air intake. Can't remember what it made on the Dyno, but he said he was really disappointed with the car. He said it really didn't feel that much stronger after all the upgrades. ...
I was curious about this as well...having driven trucks w/ 4.10 swaps w/ the 6L80 tranny (I know not apples to apples since an auto but still 6 gears) and the SOTP feel in a 3 ton truck is significant, in a 3000 lb Z06? Yeah....I'd say "traction will be an issue" is an understatement. I suppose a new set of tires would have to be in the conversation as well.
3.90s would probably be the route I'd go myself
Thanks for all the replies. I'm thinking 3.90's are going to be the way to go. The car is always on Nitto drag radials, so traction shouldn't be TOO terrible, although it would require a bit more finesse I'd say with a gear swap.
The car already has a bottle on it, and has been sprayed like twice just to ensure the system is working properly, but I don't plan on spraying the car again until I can schedule a proper dyno tune (better safe than sorry.)
I think I'm more interested in this car being fun/quick on motor versus all out speed demon, as my other car is a 1200hp (soon to be more) twin turbo Cobra, so it handles those duties. A well thought out cam/headers/x/cai combo should produce ~430rwhp on motor with a good tune, and 3.90 gears will give me back some low end I may sacrifice with a mildly aggressive cam, with the spray for 2nd gear on at the occasional track visit.
Edit: Now the question is do I purchase a whole diff with 3.90's already installed? If I were to have them installed, should I purchase an install kit, etc or are the things like motive gear a direct swap?
I researched 3 speed shops. Two of the three speed shops said they'd tried sub-letting out ring-and-pinion swaps before with bad results and eventually (joined the other and) decided just to advise their customers that they'd only swap entire differentials including a core exchange. They all said the tools were too expensive and the process too complicated to validate the cost vs. liability of getting it wrong.
I was curious about a Z06 trans and hearing. I've read that a Z06 trans and a 342 gear is like a m6 and 390 gear. So if you do a 410 in a m12 car would the first 4 gears be like a 488 gear?
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
We always build 4.10s for them...
crossing the line in 4th still.
I wouldn't do anything less.
Chuck CoW
hey im in long island and im thinking og upgrading to 3. gears in my 04 Z06. car currently has tick performance sns stage 3 cam w an intake, 1 3/4 LT and off road x pipe w a borla stinger catback, car is a strick daily driver w 40 miles driven daily. i live in long island and my commute involves almost no highway driving , how will this affect mpgs? my gas comsumption is pretty bad as it is idk why
