[Z06] FAST 90 installed today
After a couple days of making sure everything is right on the car, we finally got it together. Fast 90 ported by Tony Mamo and an ls2 Throttle body. The fuel lines were a pain and after a couple of fuel injector o-rings falling apart, the car purrs again. Put the fuel lines together with limited resources and time. This might not be the cleanest install but it works until i get around to making it pretty
Thats your breather system, you should not block it off. It should be routed either back in your intake or to a catch can. If you leave it open it will spit out oil.
