[Z06] Boost/HP calculator?
Does anybody know if there is a formula or chart to find the approximate HP gain per lb. of supercharged boost in a LS 5.7L engine? I know it will be a rough estimate,I would be fine with even a rough percentage gain per lb. of boost if there is such a thing. Thanks Rich
A&A advertises a ~175rwhp increase with their C5 kit, which I think is at ~7psi. So, figure about 25rwhp/psi for a centrifugal supercharger. That number will be lower for a twin screw or roots blower. And no matter the design, there will be diminishing returns as you increase boost, due to heat issues (unless you add methanol injection).
These are rough numbers and general rules of thumb.
^ That's closer to what a 2.0L Miata gains... it seems way too low for a 5.7L LS engine. Do you think it takes 10psi to add 100hp to the C5?
As another data point, Magnuson advertises ~120rwhp with 6psi on their C5 "hybrid-roots" supercharger, which comes to 20rwhp/psi.
The car makes 703 RWHP which equals about 800HP at the crank (approximately). From what I've been reading I think the boost is closer to 18-20 HP per lb.,if not my LS1 would be making about 650HP at the crank normally aspirated-that seems high,what do you guys think? Rich
Otherwise, if you know both the power and boost, you can calculate your own rule of thumb.
Take base engine HP / .85 to account for supercharger loss that gives you real engine HP non boosted.
800 - Non boosted HP = differential
Differential/Boost PSI = HP per lb of boost.
