[Z06] Steel Shift Fork in M12?
Just wondering if anyone knows if the shift fork in the M12 tranny was changed to a steel shift fork during the '03 production year?
If so, does anyone know at what VIN number they started using steel shift forks?
TIA
TIA
Get Some!
Re: Steel Shift Fork in M12? (lt4vette)
If they did I want one. I'm still scared to do a hard 4 to 5 shift, I'm on my second tranny because of the flimsy shift rod.
TIA
TIA
Re: Steel Shift Fork in M12? (Mike Siska)
No...The M12 does not use steel shift forks. All are aluminum. I had a steel shift fork put in when I had my 3-4 gears replaced. Shifts are much more positive 2-3 and 3-4 now. :cheers:
1.They started using the steel shift forks in the M12's around Feb. the same time they built the '04 pilot cars.
2. They started putting them in the '04 M12's.
3. And now none of them have steel shift forks.
Very confusing. :confused:
Re: Steel Shift Fork in M12? (wamara)
Mile, from whom did you get the steel fork? I'm sure many would like to know. Thanks.
2018 C2 of Year Finalist
St. Jude Donor '12-'13-'14-'15, '19
Re: Steel Shift Fork in M12? (rwd)
At the 50th Celebration, one of the engineers said that the change to a steel fork was made mid-production 2003. :confused:
