What is the target paddle shift point in RPM's for A6 Paddle Shift 06
I just got my C6 with A6 Paddle shift capability which is an upgrade from my 03 with an A4. I am wondering what the target RPM levels for shifting using the paddles in S mode would be to get the best perfromance without damaging the car.
Also what is competative mode and what does it do?
So you shift up or down based on speed vs RPM's to keep them at around 5200.
Currently in D or non-shifting S the RPM's look to be at around 2500 to 3500.
Thanks for the information
Originally Posted by wratran
is there a reason why you dont shift it at the max HP...around 6200-6500?
For road racing I have no idea, but for drag racing if you shift at 5200 rpms you are going to lose at least 2 tenths of a second in the qtr mile. Somewhere around 6200-6300 rpm's should give you your best times on a drag strip.
Originally Posted by ghostRder
The HUD should tell you when to shift in comp mode, and I believe there is a rev limiter in the A6 (there has to be).
Anyway on the 1st to 2nd gear shift you need to do it around 5200 rpms. There is a lag on this shift and at that rpm you should not hit the limiter. For the other gears you can be more aggressive. The shifts are quicker between the gears and the tach is moving slower.
Originally Posted by TMyers
Hmm now I'm going to check.
Originally Posted by shurite44
In the C5 it was in the HUD. Said SHIFT, I think at the top right hand corner of the HUD. Many people never noticed it.
Shift Light
Nope not there on the C6. Just went out and tested it.
• Shift Light
This light is used for performance driving to indicate
that the vehicle’s best performance level has been
reached to shift the transmission into the next higher
gear. An arrow pointing up will light up on the display
just prior to reaching the engine fuel cut-off mode.
This cut-off is about 6,500 RPM for the LS2 engine
and 7,000 RPM for the LS7 engine.
Originally Posted by adaca
Auto or manual, you do the same.
Up shift at rev limit, normally just above power peak, so you start out the next gear from the torque peak.
I think that the issue here is that for the Corvette’s A6 ( like many manumatic implementations ) it was decided that the behavior as the RPM reach redline \ fuel shut-off \ rev limiter ought to be as in a manual trans. Meaning, stay in the selected gear & bounce off the rev limiter.
This appears to be an issue where the lag \ delay in ( paddle ) shift request to actual initiation of the shift is long enough that the fast rising RPM in first gear can allow the engine to hit the limiter before the shift begins.
Though I do not yet have my 07 ( Fall ) my understanding from several other posters here is that if timing of paddle shift request is not perfect, and the motor does run into the limiter, there will be lost time – as once into the limiter, there is a further delay before full acceleration will begin in the higher gear.
My personal preference would be that I have a choice in such trans. behavior. But failing that, I’d have preferred that this A6 behave like the TipTronic A5 I drove for a couple of years – in that if I did not manually upshift the trans., it would automatically initiate an upshift at the redline. The thinking ( I presume ) is that if you are at WOT, and the RPM approach fuel cut-off, a shift to the next higher gear is what the driver really intends – and the driver has just been a tad slow on the draw. This behavior seems preferable to bouncing off the limiter in any real world driving instance I can think of. The sudden cut-off in acceleration in the lower gears seems more upsetting to the car’s dynamics than an upshift to the next higher gear.
But GM did not ask me . . .
- Ray
Moving closer to ordering an 07 w/A6 . . .
In most cases an LSx motor has peek tq at 4800rpms and peek hp at 6300 rpms. You want to shift above peek HP as the rpms will drop after the shift, yet you will still be in a good power band.
this is racing of course, not street driving.
the other factor is that the A6 paddle shifter does have computer algarythems to all shifting up or down with in a RPM range. If you are not within that range, even if you push the button the trans will not shift until the computer says the engine is in the shift rpm range.
Bouncing the car off the fuel cut off rpm is not a good idea, that is what red line is for and the fuel cut off is 150 rpms or so above red line.
Originally Posted by rayainsw
From the ( 2006 ) manual:
• Shift Light
• Shift Light
I've yet to see this light on my A6, built May 06, and I've hit redline a few times.
raptor shift light web site
