Horsepower increases without voiding warranties
Really depends a lot on your relationship with your dealer! Some guy on the Z section was told HEADERS on his ZO6 voided his warranty! Hence the puked engine was his dime. My dealer actually will install headers so I'm pretty sure they'll cut you some slack. I'd say once you open the engine up all bets are off but again it all depends on the dealer....
1 Post
CF Senior Member
My dealership aggressively denies warranty service for any problem even remotely related to a modification. Ask your dealership and see what they say is allowable. Let us know what they say.
St. Jude Donor '07
I almost ran in to major warranty problems with my last 2006 coupe after adding headers, stat, and a tune on top of the cai and catback.
The problem was not related to those parts, but I ended up putting the car back to stock and selling the aftermarket parts.
Now, my feeling is, any mods I make must be EASILY reversible, meaning I could do them in my driveway in less than an hour.
Now, IMO a catback is OK, I had one local service manager say it isn't, but there is NO WAY he can deny a warranty on it. It does not have any cause or effect on anything.
On the other hand, I can see a CAI causing a problem due to oil on the maf, but mainly due to water ingestion.
Therefore, I only will put on CAIs that can be quickly put back to stock in minutes if the car needs to go in for service for an engine problem.
For example, I really like the Vararam, but I will not put one on my car as removing it is not easy.
What i did was buy a K&N aircharger, easily swapped back to stock in 30 minutes and for cold air I did the "Free Cold Air Mod" by popping out the two push pins that hold the front radiator shroud in place. This allows me cold air through the front grille, but if I ever need to go in for MAJOR service, I just push the pins back in and back to stock with no signs of anything.
Call me PARANOID, but I am not taking any chances.
Howard
Howard
Moderator
Received 3,582 Likes
Bottom line, if you want 100% certianty on warranty, don't mod at all.
Best way to increase your HP and not void the warranty on your 06 is to buy an 08, or a Z06! Not being a smart **** here. Many dealers are a real pain on that. Have had a dealer tell me even a CAI will void me.
I deal with the owners of a couple of dealers. They are telling me that the manufacturers are really cracking down on warranty claims. It's actually not unusual for dealers to eat warranty claims that the manufacturer does not stand behind.
Water damage, ie hydrolock, should fall under your auto insurance policy. Check with your agent.
That service manager has no idea what he's talking about. What problem is he going to claim occured with the exhaust system?
To top it off, Furthermore, Chevy themselves offer an aftermarket system (Borla).
And indeed, there is at least one dealer in my area who sells C6s that he has already installed B&B Bullets on and the same dealer offered to install Corsa Tiger Sharks on my C5 before I took delivery of it.
1 Post
Are you referring to Yello3's post where he says: "Now, IMO a catback is OK, I had one local service manager say it isn't, but there is NO WAY he can deny a warranty on it. It does not have any cause or effect on anything".
To top it off, Furthermore, Chevy themselves offers an aftermarket system (Borla).
A local GM dealer installed my GM off road exhaust (Borla) .
Didn't Les Stanford install Corsa's on most of their C6's?
http://www.chevrolet.com/corvette/accessories/
I"m pretty sure if the car hydro locks with the stock intake, the manufacturer is responsible for that, as long as you didn't drive it through a lake or something. I know a guy I worked with hydrolocked his mustang just driving through a puddle around here and they warrantied it.
I did some searching..looks like aftermarket exhausts will not void your warranty, but I would talk to your local dealer first and feel him/her out and see if they can install it for you.
I see the old mod-warranty agrument is running again. There is a very simple truth you need to know - if you can't afford to fix it, don't modify it. Period. End of debate.
Every so often, someone in here throws out the good ol' federal warranty law - the Magnuson-Moss Act. It says that the mfg. must honor its warranty UNLESS the damage was done by a non-standard part or due to misuse (i.e. racing or abuse). I've seen many people try to claim that their damage has nothing to do with the modification and, therefore, should be covered under warranty. In theory, they are correct. In practice, it rarely, if ever, works out that way.
If GM can find ANY semi-legitimate justification for denying a warranty claim, they will do so. Period. Granted, if your claim is for a broken radio, GM would be hard pressed to deny it because you put headers on your car. BUT, if it were something mechanical or powertrain related? They'd most likely deny it. If it were an electrical modification you made (like installing one of those do-it-yourself HUD's)? Deny almost anything remotely related to the electrical system.
If the dealer sold you your non-GM mod (say, exhaust or headers), then THEY would have to warrant the work, NOT GM. GM isn't going to pay for engine damage because someone else put an engine mod on their standard car. If the new part is a GM part, then GM warrants it. Simple as that. Again, don't mod it if you can't pay to repair it.
