Rotor rust ring... any removal products?
Old 06-01-2007, 10:53 PM
CRG517
CRG517's Avatar
Default Rotor rust ring... any removal products?
I am interested in cleaning the rust off the inner rotor portion and then attempting to keep water away from it or recleaning it as necessary a couple times a year... has anyone had a any success doing this, I'm really not ready to replace or go to the expense to have them zinc coated... yet! Thanks in advance.
Old 06-01-2007, 11:10 PM
HoleInOne
HoleInOne's Avatar
Take the wheel off and paint it black.
Old 06-01-2007, 11:26 PM
slomarsh
slomarsh's Avatar
I have used two different can sprays with great results.
Light gray primer and spray on zinc are both very good color matches to the original factory gray. The zinc is more widely available now at ACE hardware,etc. Otherwise any welding supply house will carry it. The zinc will, of course, prevent new rust from forming. The primer seems to hold up pretty well too. If you wash often or drive much in the rain zinc might be the better choice. A spray can of zinc cost about $7.
Oh, and application is easy. Just tape off the calipers and spray away.
Overspray on the rotor will be gone the first time the brakes are applied.
Old 06-01-2007, 11:38 PM
ben dover
ben dover's Avatar
Location: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Or spray galvanizing.
Old 06-01-2007, 11:48 PM
Comfortably Numb
Comfortably Numb's Avatar
Should you use a self etching primer?
Old 06-01-2007, 11:53 PM
slomarsh
slomarsh's Avatar
Yes, spray galvanizing and spray zinc are the same thing.
I have not used self etching primer though it would probably adhere even better than normal automotive primer.
Old 06-02-2007, 12:22 AM
shopdog
shopdog's Avatar
Use a stainless steel wire wheel to remove the rust (don't use an ordinary steel wire wheel, the little carbon steel bits it'll leave embedded will rapidly rust and form new pits), then paint the offending areas with Zinc-It or POR-15. Even barbeque grill paint will hold up on the rotor hats.
To Rotor rust ring... any removal products?
Quick Reply: Rotor rust ring... any removal products?
