06 Z51 Lower than Base Suspension?
Old 08-16-2007, 10:22 AM
jthorn
jthorn's Avatar
Default 06 Z51 Lower than Base Suspension?
I just bought an 06 Coupe with the Z51 suspension package and was wondering if it is lower than the base suspension?
Old 08-16-2007, 10:24 AM
M321
M321's Avatar
I do not believe it is lower, stiffer but not lower.Unless im wrong.
Old 08-16-2007, 10:28 AM
JLMounce
JLMounce's Avatar
Ride height is set by locating the lower control arms in relation to the frame rails.
The z51 packages is not lower than the base suspension. Just sprung stiffer, coming with stickier tires and a bit lower gearing in the transmission is the car is MN6
Old 08-16-2007, 10:46 AM
jthorn
jthorn's Avatar
Default Thanks Gents!
Ain't the Forum great!!!
Old 08-16-2007, 05:09 PM
Les-10
Bow-Tie Guy
Support Corvetteforum!
Les-10's Avatar
Roger That!
Old 08-16-2007, 05:18 PM
C6400hp
C6400hp's Avatar
Location: DFW This user does not support or recommend the product or service displayed in the ad to the right
It is when the information is correct which is not the case here.
The Z51 recommended trim height is in fact lower than the base or F55 cars. When measured from the Z or D trim height locations it is a millimeter lower. Whatthat translates to in ride height from the ground to body I am not sure but I would guess somewhere between 1/8" and 1/4" lower if measured at the fender or other body location.
Old 08-16-2007, 07:57 PM
drivinfast
drivinfast's Avatar
Used? If you bought it used it could have been lowered. Or even new, the lowering/raising bolts may or may not be set to fact specs
To 06 Z51 Lower than Base Suspension?
Quick Reply: 06 Z51 Lower than Base Suspension?
