Help: How to Adjust Trunk Latch on Vert
Old 03-05-2017, 12:04 PM
C6ZHZ
2nd Gear
C6ZHZ's Avatar
Default C6 'vert trunl lid adjustment.
Have '09 'vert with trunk lid closing about 3/32" below being flush with rear deck. Adjusted stops on either corner of lid, but center latch area still latching below deck lid at center. Opened up latch area behind carpet cover on body. #30 torx heads loosened and no adjustment. Looked at latch on trunk lid and loosened each side (#30 torx again) and viola' it slides. Downward raises lid when closed and raiding caused lid to close lower in relation to rear deck. Also made trunk easier to close with one push, whereas before I had to push once and then follow with a second firm push. If I did not do second close, it would tell me trunk was not securely closed and top would be restricted from cycling. Hope this helps. EASY FIX with no parts (shims unnecessary) and saving $$s and having to go thru rocket science at dealer. I'm sure some tech knows this adjustment, just charges $130 hr. to make 5 minute adjustment.
Old 03-05-2017, 12:45 PM
cclive
cclive's Avatar
If adjusted correctly, the lid will close with just a tap to get it started falling.
Old 03-05-2017, 12:56 PM
C6ZHZ
2nd Gear
C6ZHZ's Avatar
Default trunk lid adjustment
It does not pull down with power. It simply latches with a push. Much lighter push after adjustment.
Old 03-05-2017, 04:19 PM
65GGvert
65GGvert's Avatar
Received 3,220 Likes on 2,302 Posts
I learned on my 09 what a couple of guys posted earlier. If you lower it till it sits on the latch, then push down with your hand it takes very little effort to latch. No slamming needed.
Old 03-05-2017, 09:44 PM
65GGvert
65GGvert's Avatar
https://www.youtube.com/watch?v=hMhf...ature=youtu.be
Old 03-06-2017, 01:15 AM
owc6
owc6's Avatar
Received 4,186 Likes on 2,679 Posts
I just slam it down.
Granted, my slamming force isn't as much as was a couple of hundred thousand miles ago, but it has hurt or cracked anything yet.
I don't slam and continue with the hand on the deck lid after latching, just an "I told it who was boss" type of slam to get things moving.
I'm sure that those watching me close the lid wonder what I have against the poor car.
Quick Reply: Help: How to Adjust Trunk Latch on Vert
