Old 02-23-2015, 03:14 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Exterior How-Tos
Browse all: Engine and Powertrain
Print Wikipost
Stock muffler mod...
Old 01-19-2008, 09:52 PM
keith5
Support Corvetteforum!
keith5's Avatar
Default Stock muffler mod...
Has anybody taken a long chisel and stuck it up the tailpipe and punched thru a baffle? (Dont get gross here Knooger).
Just curious if a simple little mod like that could improve the stock exhaust note?
I'm damn tempted.
Has anybody modified the stock muffler?
Old 01-19-2008, 09:56 PM
Ozone
Ozone's Avatar
IMHO...the cheapest exhaust mod is to replace the stock cans with MagnaFlow 14335s (or 14336s). About $87/ea + ~$150 for install. 200% better sound for less than $350.
Old 01-19-2008, 10:08 PM
theVcar
theVcar's Avatar
St. Jude Donor '08
What about tips? Does the $200 cover the weld for the tip replacement. I thought the better way to go was the Flowmaster 17427 for $375 + install.
MikeyTX
MikeyTX's Avatar
Received 2,186 Likes on 1,337 Posts
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Default The inside of your stock muffler can
Are you sure you really want this mess on your car ? Name:  2006_0415Image0004Small.jpg
Size:  4.2 KBName:  2006_0415Image0002Small.jpg
Size:  28.1 KBName:  2006_0415Image0003Small.jpg
Old 01-19-2008, 10:26 PM
Ozone
Ozone's Avatar
I went cheap and had them reuse my stock tips. IMHO...the MagnaFlows are a better option since the Flowmasters are not stainless.
Old 06-18-2008, 09:42 AM
not2brite
Cruising
not2brite's Avatar
Default Followup to modifying stock muffler
I'm a new owner, and I've had the same thought about the stock muffler. I can afford a new system, but it gravels me to throw away prefectly good mufflers and pipes. Has anyone figured out how to modify the existing ones to get a better sound? It's done alot on motorcycles.
The following 3 users liked this post by not2brite:
98Gambler (09-25-2015), kite167 (12-18-2019), sd45t2 (07-09-2021)
Old 06-18-2008, 10:25 AM
talon90
talon90's Avatar
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Here's what the inside of the stock muffler looks like. This will give you a target to aim for.
IRingTwyce (03-13-2017)
Old 06-18-2008, 11:44 AM
cclive
cclive's Avatar
I have thought exactly the same thing....will have to investigate...I really only want about 10% more sound...not alot...thanks for the pics...
Old 06-18-2008, 11:50 AM
talon90
talon90's Avatar
NCM Ambassador
The current exhaust travels along the curved pipe into the chamber where you see the fiberglass packing and exits in to the chamber via the perforated holes. It then is dampened by the packing and exits out the perforated tail pipe. The best way to gain a little sound if you could access the chamber would be to remove a small quantity of the packing material.
WoodChuck2
WoodChuck2's Avatar
Old 06-18-2008, 12:01 PM
KyleBst264
KyleBst264's Avatar
An easy and FREE way to gain some exhaust note. Go into the fuse panel under the passenger side floor. Pull out the fuse for the exhaust, and the baffles will stay open.
Old 06-18-2008, 12:06 PM
F40
F40's Avatar
Do all c6 have this fuse ?or just the ones withe dual mode exhaust?
Old 06-18-2008, 12:08 PM
not2brite
Cruising
not2brite's Avatar
Most excellent picture! I think, looking into the back end of mine, that the flow is actually out the curved pipe. I don't see why I couldn't drill a small exploratory hole into the glass mat area and try to remove some material. Small enough to be plugged if it works. From the pic the center section appears to be the only area of sound transfer within the muffler. Maybe the rest is for resonation, (is that a word?) but I bet it's only for housing the pipe bend. I'll give it a try.
Old 06-18-2008, 12:34 PM
cclive
cclive's Avatar
Where the heck did you come up with a pic of the stock muffler sliced in half....amazing!
Old 06-18-2008, 12:38 PM
talon90
talon90's Avatar
NCM Ambassador
My friends at Corsa Performance had done it as a side by side with their Corsa Extreme.
Old 06-18-2008, 12:44 PM
talon90
talon90's Avatar
NCM Ambassador
If you look closely at the photo you can also see that the front and back chambers are used for resonance as well. Just under the "k" on the word stock you can see a round opening that goes in to the front chamber and you can see a small amount of the glass packing going in to the hole. Just under the perforated pipe at the top you can see the bezel of a round opening that goes in to the back chamber. The front chamber also is fed with overpressure from the front perforation on the top pipe as well. I think that it is pretty fascinating really to look at the cross section.
I think your idea has merit. The center section accomplishes most of the sound reduction with the glass pack. I think that an exploratory surgery of sorts could yield some improvement. Bear in mind however that these are strands and they appear to be fairly nested. Pull too long and too hard and you will displace a large amount of packing in a short period of time. It could end up with more than you bargained for. Good luck with the experiment and do post your results for us if you wouldn't mind.
Paul
CorvetteBrent (11-20-2019)
Old 06-18-2008, 12:48 PM
danl72
danl72's Avatar
I don't think they are talking about the NPP.
To Stock muffler mod...
Old 06-18-2008, 12:54 PM
talon90
talon90's Avatar
NCM Ambassador
Of course you do realize that only the 2008 cars WITH the NPP optional exhaust have this as an option, right? The rest of us don't have a fuse to pull and if we did, it wouldn't do anything as we don't have the butterfly valves to change state.
The following 2 users liked this post by talon90:
chrisharek (06-18-2019), CorvetteBrent (11-20-2019)
Old 06-18-2008, 01:15 PM
CraigE
CraigE's Avatar
My 07 C6 has a 10 amp fuse at the bottom right of the passenger footwell that says exh.
I don't think it does anything though.
I think they use the same fuse boxes on the Z06 ,which would use the fuse.
One less thing to keep track of at the plant.
Old 06-18-2008, 01:21 PM
F40
F40's Avatar
Thankyou for clairifing that.
Quick Reply: Stock muffler mod...
