Navigation system questions
Old 06-16-2008, 09:01 PM
0to60
0to60's Avatar
Default Navigation system questions
I'm considering a C6 and I really like the navigation system in my acura, and I'm wondering how chevy did in this dept.
A) Can I mess with it while driving? Lexus feels that if a driver were to mess with the navi while driving he would crash and burn, so most functionality is available only when the car is parked. Is that how the
C6's navi works?
B) Is it a DVD based system? How much do updated DVD's cost?
C) I see there are two slots behind the screen, CD and DVD. I imagine the CD slot is for playing music CDs, but what's the DVD slot for? Is this where you put the map DVDs? Can I play movies in there? If so, can I play movies while the car is driving?
Old 06-16-2008, 09:06 PM
mcandrew67
mcandrew67's Avatar
Received 1,013 Likes on 599 Posts
2016 Corvette of Year
2015 C6 of Year Finalist
1. No you cant enter while driving, you can do pre entered or previous destinations while moving
2. You cant watch movies in the dvd that is for the map discs
3. You should get a couple of years of free updates un less they discontinued it, other than that I believe they are almost $200
Overall I like the system but thats a big debate on here, you will get as many different answers as you can start threads.
Old 06-16-2008, 09:11 PM
Brian_B
Support Corvetteforum!
Brian_B's Avatar
I have a 2007 and my screen is showing funny lines on the right hand side. Pissing me off but don't want the dealer to touch it. I've lost faith in all shops now.
Old 06-16-2008, 09:15 PM
matsarge
matsarge's Avatar
...it's really not fair to compare the C6 NAV to the Acura since IMO they make one of the best systems out there.
I have NAV and it does exactly what I need to it and I have no complaints. One nice feature of the C6 NAV is it feeds information to the HUD so you don't have to look down at the screen.
Old 06-16-2008, 09:25 PM
FortMorganAl
FortMorganAl's Avatar
Location: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
  1. No, you can't start from scratch to enter a destination while driving. You can enter and save over 100 destinations while stopped and then select any of those while driving. That should be enough for any salesman or vacation. You can change the type of routing while moving. You can get an automatic rerouting just by not going where it tells you to go.
  2. Yes, the maps are on DVD. I believe they are about $200 unless you got an 06 or 07 in which case you get 2 free updates. But you don't really need the updates. Most roads don't change that often and it will always get you there though it might take a little longer if you have an out of date map. And we won't mention the threads here about burning your own.
  3. The CD slot is for CDs and MP3 discs. The DVD slot is for the map DVD.
BTW, I wouldn't have a Corvette without the factory nav.
Old 06-16-2008, 09:42 PM
*FAÇADE*
PHOTOSHOP SPECIALIST
*FAÇADE*'s Avatar
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Not to worry . . . perfectly normal.
Old 06-16-2008, 09:46 PM
VET4LES
VET4LES's Avatar
I love mine and will never buy another car without a factory NAV. You can add a GM 6 disk CD player that works through the NAV for around $500.
Old 06-16-2008, 09:59 PM
Another Don
Another Don's Avatar
The Corvette OEM NAV is adequate...but only adequate. It pales in comparison to the Acura NAV system. About the only thing the two systems have in common is the the requirement to push the OK softkey to make the legalese warning go away.
IMO, the NAV integration is not only overrated, it's annoying. I can't stand the HUD showing me that I'm closing in on my freeway exit that's 2...1.9,,,1.8...1.7...etc down the road. There are simply much better systems out there in the aftermarket.
If it were me, I'd buy the Vette with the 6-disk CD player and then swap it out for an aftermarket NAV system.
Just my $0.02. YMMV. Now donning my asbestos underwear...
Old 06-16-2008, 10:16 PM
BigL50
BigL50's Avatar
I have a Garmin system for my other vehicles. I actually prefer it over the Vette Nav System based on user friendliness. I like the fact my passenger can navigate the system while I drive. In the Vette, they cannot.
Old 06-16-2008, 10:36 PM
0to60
0to60's Avatar
Ok, so what CAN you do while driving? I find that I don't use nav for giving me directions all that often. First of all, the address I need to go to is NEVER in the database. I like google maps for that sort of thing.
At any rate, I DO use the nav to look around at roads while I'm driving. I'll be on this road and I'll wonder what happens if I turn down that road, so I'll move the map around and zoom in and out and stuff. Can you do that while driving?
Old 06-16-2008, 10:42 PM
phileaglesfan
phileaglesfan's Avatar
I definitely wouldn't base my decision on owning a Vette due to the NAV system especially the one that is in the Vette.
And yes roads do change often. It is called development.
Old 06-16-2008, 10:44 PM
BigSlick
BigSlick's Avatar
Old 06-16-2008, 10:47 PM
Hogvette
Hogvette's Avatar
It is rather simple to add a switch that allows you to enter data while moving... I did this mod and located the switch in the ashtray cig lighter location. check out this site from CF member Ray Kawal:
http://www.kawal.net/navigation.htm
Old 06-16-2008, 10:54 PM
jimmie jam
jimmie jam's Avatar
Old 06-17-2008, 12:31 AM
matsarge
matsarge's Avatar
you can zoom in and out but I've never tried moving the map around while driving.
Old 06-17-2008, 12:55 AM
kawal
Emerging Vendor
kawal's Avatar
With a fairly simple modification, you can.
Here is the forum link to fix this aggravation:
http://forums.corvetteforum.com/show....php?t=1732903
I can't compare it to other factory navigation systems, but I like my Vette factory Nav a lot, and I definitely would order it again. My wife and I used it a bunch last year on a great 8500 mile road trip. It is very nicely integrated into the entire entertainment system and the HUD.
Ray
Old 06-17-2008, 01:24 AM
redzr1
redzr1's Avatar
You should return this to have it replaced. Either the display or its video driver is starting to fail. I would expect over time this is only going to get worse. When it fails out of warranty it is going to cost on the order of $2000 to replace the unit as I don't believe that you can just get repair work done through the dealerships.
To Navigation system questions
Old 06-17-2008, 06:11 AM
mcandrew67
mcandrew67's Avatar
You dont have to have it show in your HUD, change it from street mode to another mode and it won't show in your HUD
Old 06-17-2008, 07:19 AM
beepster
beepster's Avatar
Wish I could just sell you mine...I love the idea of a NAV system in a car but consider the one in the vette worthless. Don't even use mine anymore!
Old 06-17-2008, 07:27 AM
Snagle
Snagle's Avatar
Yep, you CAN scroll and zoom the map while driving.
Like most any GPS navigation system, if you zoom out, many of the smaller roads will not be visible. (They reappear when you zoom in.) Since I spend considerable time on the smallest backroads, I have to stay zoomed in fairly tight in order to show the road I am currently driving.
Quick Reply: Navigation system questions
