Synpower 4 x better wear than Mobil 1
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
I would check that it meets the GM standard (4718M??) on the specs. I know Castrol's full syn doesn't, or isn't printed on the label. I thought I saw that Valvoline's full syn doesn't have it on the label either. If you look at Mobil 1 or Pennzoil Platinum, both do state it meets GM's standards.
Just a thought....not trying to start an argument.
Here's the page from Mobil Oil (http://www.mobiloil.com/USA-English/...1_5W-30.aspx):
Mobil 1 5W-30
The Mobil 1 5W-30 grade delivers the viscosity recommended for most General Motors vehicles and many imports. Mobil 1 5W-30 is the first choice of premium car manufacturers, including Corvette. Mobil 1 5W-30 meets:
* GM 6094M, GM 4718M (Corvette spec)
* Ford WSS-M2C929-A
* Honda HTO-06
* ACEA A1/B1
* ILSAC GF-4 (API Certified - Starburst)
Mobil 1 5W-30
Mobil 1 5W-30 is an ILSAC GF-4 energy conserving viscosity that provides excellent all season protection. This product also meets the requirements for diesel-powered vehicles where an API CF or CD oil is recommended.
Mobil 1 5W-30 is recommended for all types of modern vehicles, including high-performance turbo-charged, supercharged gasoline and multi-valve fuel injected engines found in passenger cars, SUVs, light vans and trucks.
* Mobil 1 5W-30 is general purpose engine oil for all types of vehicles where a 5W-30 viscosity is recommended.
* Mobil 1 is not recommended for 2-Cycle or aviation engines, unless specifically approved by the manufacturer.
As are all Mobil 1 products, it is designed to provide outstanding wear protection, maintain excellent engine cleanliness, and the performance reserve to keep engines in newer cars running smooth and clean.
For more information, see the Mobil 1 5W-30 Product Data Sheet and Material
Mobil 1 5W-30
* Ford WSS-M2C929-A
* Honda HTO-06
* ACEA A1/B1
Mobil 1 5W-30
I vote for Mobil 1 and here is why. I've been using it for some 30 years. I have a 1993 Jeep Grand C with a 318 CU inch motor that's been on Mobil 1 since new and changed every 6000 miles until three years ago when I quit using it as a daily driver. Now it gets changed every couple of years. That Jeep runs like new and does not need oil added after 6000 miles and the car has over 205,000 mile on it. A couple of months ago I did an oil change on it and used the new 0W-30 Mobil 1. After all those years on 10W-30 I can feel the difference.
I use Mobil 1 20W-50 in my Harley Davidson bikes.
There may be better oil out there but this stuff is good enough and it's available at Wally World. It's also 100% PAO ( Poly-Alpha-Olefin or 100% synthetic )and resists heat well.
I first encountered Mobil 1 back when it was first being used by the Air Force in C9 jets - that was more than 30 years ago. I figured if it was good enough for jet engines it was good enough for my Corvettes.
My last Corvette, a C4, had 186,000 Mobil 1 miles on the odometer when I traded it for the C6. The C4 is living happily 40 miles north of me, now, with 225,000 on the clock....
The GM list for 4718m doesn't show the Valvoline:
GM4718M Registered Products
Revision Date: 28-Feb-2008
Product Name SAE Viscosity Grades
AC Delco Full Synthetic 5W-30
Castrol SLX Professional 4718 5W-30
Chevron Supreme Synthetic 5W-30, 10W-30
CITGO SUPERGARD Synthetic 5W-30, 10W-30
Mobil 1 0W-30, 5W-30, 10W-30
Northland, Synergy Synthetic 5W-30
Pennzoil Platinum Full Synthetic 5W-30, 10W-30
Texaco Havoline Synthetic 5W-30, 10W-30
Q HorsePower 5W-30, 10W-30
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'17,'18-'19-'20-'21-'22
Note for hot-weather locations
See all the 10W-30 that is approved to GM 4718m ?
(yeah, maybe I am trying to start something . . . )
Considering the source.. and "what independent" testing and what did they test?.. lot's of holes... I have one word
PAOs (Group IV base stocks) are far superior to Group IIIs regardless of additives!
1 Post
I am thinking about trying RLI's new stuff.
http://www.renewablelube.com/motoroilsinformation.htm
Here's more info about it on the M3 boards:
http://www.m3forum.net/m3forum/showthread.php?t=172664
CI 2-3-4-5-6-7-8-9-10 Vet
St. Jude Donor '09-'10
I used Mobil 1 once in my C3 and it leaked out so I went back to Castrol and haven't had any problems with the engine, it's got almost 200k miles on it now, but I do and will continue to use Mobil 1 in my C6.
