How to remove driver door window switch paneL
I know I know... I looked in the FAQ section. Didn't see it for the C6
Anyone know if there is a special way to pop off the driver door window switch panel?
Does it matter which end I try to pop it up first?
Front/back
Don't want to snap a tab off or something.
Front/back
ELEVEN years later ..................same question
HOW do you Be Careful and Pry the Window/Mirror Switch Panel Up/Out from its Home
06C6Man (05-23-2020)
Here you go, from the How-Tos section of this forum. https://www.corvetteforum.com/how-to...r-panel-368469 There's this thread also. https://www.corvetteforum.com/forums...anels-off.html
