Help: radio won't turn on....
Old 03-30-2010, 11:55 PM
mattl182001
mattl182001's Avatar
Originally Posted by cclive
I remember hearing about TWO fuses also....maybe there is more than one that needs to be pulled....hopefully someone who knows will chime in...
Thanks for the responses, guys! I am not exactly sure which two fused to pull. I did pull the radio fuse lableled "RDO" and the "Accessory" fuse. Are there others I should try. I did pull every fuse that wasn't labeled with an obvious description. But maybe the amp or radio could be tied in with another system and share the same fuse?? I will be going to the dealership in the morning. If I do have to replace it, I want to get the best bang for the buck and will retain the "navigation" package.
Matt
Old 03-31-2010, 05:54 PM
Mike Green9
Mike Green9's Avatar
Engine compartment: #31 Audio Amp
Passenger Footwell: Radio, S-Band, VICS (on my 2008), may differ as per model year.
Again if in doubt, pull the positive battery cable, wait 1 minute, and try again.
M....
Oop - That should be pull the NEGATIVE cable and wait 1 minute.
Old 12-22-2013, 08:42 PM
jubbs
1st Gear
jubbs's Avatar
Default my c5
my clock works but the radio wont power up or display loc or sec ? just got the car and put in a new optium battery any suggestions
Old 12-23-2013, 09:18 AM
Mike Green9
Did you check the 2 fuses:
Try disconnecting the negative cable - if that fails I would try posting in the Audio Portion of this forum.
Please let us know what happens.
Thanks,
M...
Old 08-06-2015, 03:33 PM
C3 Jones
C3 Jones's Avatar
Location: You think your hauling gass then you Then you Look in your Mirror and Oops there I am
Thanks,
M...
Thanks Mike Green9
I have had my C6 for only a few months and went on Vacation for 2 weeks and the battery was dead when i got back. Charged the Batt and when i started the car NO RADIO NO Navi NOTHING. I wigged out thinking I killed it charging the Batt somehow.
Done as you suggested checked fuse and then undone the Neg batt cable for 30 seconds and BAM!!! i got Van-Halen rocking out the speakers again.
Again thanks for the Post I was sweating buying a new head unit.
Old 07-28-2016, 02:10 PM
denstrim
1st Gear
denstrim's Avatar
Originally Posted by 60av8tor
Success !
It was the radio fuse ( under the toe board, pax side). I pulled it and, at the suggestion of my wife, put it back in without waiting overnight.
Fired right up after I turned the car on.
Perhaps this should be a sticky issue, seems to happen to a lot of folks.
Take it easy, ya'll
Thanks so much for this, just did it and my radio now works. Thanks to you and your wife!
Old 03-10-2018, 01:36 PM
carnutsx2
carnutsx2's Avatar
It worked, I had let the car sit and the battery voltage got low. All it needed was to be reset by unplugging the power .
Old 03-11-2018, 11:06 PM
buckmeister2
buckmeister2's Avatar
Received 1,206 Likes on 824 Posts
Proof that 8 year old threads have value. More knowledge on this site than at any Chevy dealer, anywhere...
August McLaurin (09-17-2022)
Old 12-03-2019, 11:36 AM
gfox
gfox's Avatar
Default Removing and replacing fuse worked for me too!!!
This worked for me too!!! Thanks!
Success !
Take it easy, ya'll
Old 01-13-2020, 08:40 PM
The Clevite Kid
Support Corvetteforum!
The Clevite Kid's Avatar
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'17,'18-'19-'20-'21-'22
Default Thanx for pulling this old thread forward
Success !
Me too: 2006 Base with base radio, 35,000 miles. Radio worked fine this morning - heading home this evening NO RADIO, and no lights on the radio. Pulled the radio fuse in the passenger footwell and it looked ok. Put it back in about two minutes later, walked around the car and went into accessory mode, and the radio was back working - with the clock reading 12:02 at 7:30 pm this evening.
THEN I went to the Corvette Forum to ask about this issue, and as so many have said "Search is Your Friend." Add me to the "lot of folks" to whom this has happened.
Old 06-28-2023, 06:37 PM
jafo09
5th Gear
jafo09's Avatar
Same - 2009 Z06, let the battery get too low (able to barely start the car then not able to start it); charged battery but then head unit would not turn on. Pulled fuse (passenger side behind toe-kick, 3rd from right, 2nd from bottom), inspected it, was fine, put it back in then head unit came on again...
Old 06-29-2023, 07:37 AM
Bominator
Bominator's Avatar
Probably not the same problem but in cold winter temps my base radio doesn’t come on immediately and sometimes not at all. Warm summer temps and there are no issues.
Quick Reply: Help: radio won't turn on....
