Ever been locked INSIDE your Vette?
Old 12-03-2010, 09:51 AM
C7Joy
C7Joy's Avatar
Only happened once, in the dealer's showroom, because the battery was dead. Sales explained about the emergency door release at that point. I bought the car with a new battery installed, no more trouble.
Old 12-03-2010, 10:36 AM
gunterwalker
gunterwalker's Avatar
Location: Cape May, NJ; Guntersville, AL; Orange Beach, AL
As usual with these cars check the battery first. If it comes back good check it again. Most issues with weird stuff like this are fixed with a new battery.
Old 12-03-2010, 10:48 AM
navyndi2
navyndi2's Avatar
Originally Posted by chris12.8
That's the first thing I thought of
Old 12-03-2010, 10:49 AM
robertaj
robertaj's Avatar
I love how people buy a 60+k car and dont even read the manual but you buy a cell phone or somthing for 100 bucks and you read it.....
Old 12-03-2010, 10:59 AM
johnodrake
Moderator
Support Corvetteforum!
johnodrake's Avatar
Received 3,579 Likes on 1,619 Posts
Originally Posted by 08crm
UM,You do know about the emergency release door lever on the floor by your left leg and right leg on the passenger side,right?
Apparently not - at least at the time!
Old 12-03-2010, 11:02 AM
Blue Demon Owner
Blue Demon Owner's Avatar
Old 12-03-2010, 11:04 AM
Blue Demon Owner
That is hysterical !!!
Old 12-03-2010, 11:20 AM
FrankTank
FrankTank's Avatar
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
If you picked the car up, and the FOB was sitting on the consul, I bet the battery was going dead in the car... the FOB will drain the car battery if left inside the car.
Old 12-03-2010, 01:04 PM
BoosterClub
BoosterClub's Avatar
This is backed up by? Doesn't seem like that would happen, one would assume the car would power down like normal until some sort of activity like a door was opened or button pressed before looking for the FOB again after the sleep mode started.
Old 12-03-2010, 01:41 PM
6spdC6
6spdC6's Avatar
Location: Northern NYs Adirondack Mountains,http://www.visitsacandaga.com.
I HAD a 05 for 2 years with the real DBS problems (happened about 10 times) It would be OK to get in the car but then it went click click and nothing, no power to open the door. I got in the habit of opening the car and starting engine before I would close the door. If I have not driven the 07 Z06 car in a few days I still do that just in case.
Old 12-03-2010, 01:45 PM
CO Lightfoot
CO Lightfoot's Avatar
Originally Posted by PrimeTime327
...I have a two month old battery with a full charge, my lights were the normal brightness, unlike me!.lol
Just went back to it and there is a very faint buzzing sound when I push the Start,Acc,Stop switch and the brake pedal is very stiff?
The car battery might still be the problem. Might be defective, possibly a bad cell. More likely, the Service Dept did who-knows-what to drain the battery.
Or maybe another problem is killing your car battery.
Or maybe your fob battery is weak/dying. They're only good for ~3 years depending on usage.
Even with a bad fob battery, the glovebox slot should work... try that the next time you get "NO FOB DETECTED".
Old 12-03-2010, 01:54 PM
Cybernetic Medic
Cybernetic Medic's Avatar
HAL is alive and well. Sorry Dave, I can't allow you to do that.
Old 12-03-2010, 03:53 PM
  #33
Gary '09 C6
Gary '09 C6's Avatar
totally !!
Old 12-03-2010, 04:22 PM
  #34
wolverine1
wolverine1's Avatar
The C6 is full of electrical gremlins!!!
Old 12-03-2010, 05:03 PM
  #35
N8sFavToy
N8sFavToy's Avatar
Apparently not, but he will now.
Old 12-03-2010, 06:06 PM
  #36
FortMorganAl
FortMorganAl's Avatar
Location: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
WRONG!!! The car only talks to the FOB when you push a button either on the FOB or on the car. There is no ongoing conversation between the 2.
Old 12-03-2010, 06:16 PM
  #37
cclive
cclive's Avatar
A very common misunderstanding of the way the system works.
To Ever been locked INSIDE your Vette?
Old 12-03-2010, 06:38 PM
  #38
JoesC5
JoesC5's Avatar
Received 1,699 Likes on 1,213 Posts
My C6 doesn't like me. It's happy when I open the door and leave. No way it's going to try and stop me.
Old 12-04-2010, 12:36 PM
  #39
jmarch313
jmarch313's Avatar
Originally Posted by lastcowboy
left someone setting in the car and took off......came back later she
was still setting there screaming she could'nt get out,,she did'nt know about the release and i forgot about it auto locking....
...same story, my wife has been locked-in a couple of times, when I left the car for a few minutes.
Old 12-04-2010, 12:39 PM
  #40
johnodrake
Moderator
johnodrake's Avatar
No it won't. The car doesn't send a request to the fob until something tells it to - like pressing on the door pad or start button. The fob doesn't send anything to the car unless it gets a request from the car or you press a button on the fob.
Quick Reply: Ever been locked INSIDE your Vette?
