Vette bucking when shifting from 1st to 2nd
Hello, One momth now in my bone stock 08 manual Corvette and I have notice under hard acceleration when I take first gear almost to redline that the car bucks or stutters when shifting to second. Is this my technique? is t the taction control kicking in? Or do I need to run it by the shop? Many thanks and Merry Christmas. Kevin
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
would it be insulting to tell you that you're shifting too late in the power band and thus hitting the rev limiter at redline? that's my thought on it.
CF Senior Member
Do you know what happens when you hit the rev-limiter? I wouldn't make a habit out of it but try running it out in 1st or 2nd gear without shifting and see what happens when you bump the rev-limiter (Note: when you hit it back off the throttle). This should tell you if that's the issue or its something else. Once you've experienced hitting the rev-limiter...don't do it again!
Sometimes she'll buck when ya don't use yer stick just right. Try to lighten up a bit...you know, the torque/power curve flattens out at some point prior to redline ( I'd have to look it up to know. )
You know, sometimes it gets to be "too much" and that's when you have to lighten up your touch. She's just lettin' y'all know in her own special way. You'd get yer feelins hurt if she came right out 'n tol ya.
