Flickering Headlight (HID)?
Just noticed my drivers side low beam (the HID) headlight is flickering - fast. Not blinking, flickering. Not sure if HID bulbs flicker when they are about to fail or if it might be the balast. Have GMPP and I suspect if its the bulb I am out of luck but if its the ballast, should be covered...
Any thoughts on the problem? Passenger side low beam is just fine.
I couldn't find any similar problems when searching.
When I see this at the shop it's always a bulb going south. Of course I work for Lexus but I assume Chevy uses bulbs like everybody else. Wonder if they cost $185 like the Lexus bulbs do.
Hello,
It’s been a few days since you posted this so I was wondering if you’ve made any progress regarding your headlights. Have you taken it to the dealership at all or are you planning to attend to this on your own?
Thanks,
Laura
GM Customer Service
Thanks,
Laura
GM Customer Service
It's probably the bulb. I just had the same condition on an HID bulb (rapid flickering) and it was the bulb...ballast was fine.
I'm not that familiar with the various HID's but when I changed the HID's in my C6(from 4300*K to 6000*K) I thought the bulb and the ballast where combined in one unit. At least the bulb and a box attached to it were one unit.
Heading to my local corvette mechanic to have it diagnosed, he does GMPP, so hopefully it will be covered. It really isn't a great design that requires a tire to be removed to replace a headlight bulb. Made even worse when it takes specialized equipment to safely raise the car to take the tire off - not a job for the casual do-it yourselfer. I'll let you know tomorrow what the verdict it.
Received 1,500 Likes
Flickering Headlight Update - Its the ballast
Verdict is in and in this case my flickering headlight problem was the ballast.
Good news is GMPP covers ballast.
Bad news is, well if you are going to replace the ballast you should also replace the bulb, and if you are going to replace one bulb, consensus is you should replace both so the light pattern/coloring is same.
At $180 plus each for the GM bulbs, I have gone with aftermarket HIDs at about $90 for the pair, lets hope they hold up.
In the end net cost out of pocket will be $90.00 for two bulbs and .7 hour for changing one bulb (thats shop rate).
As for the gentleman that says its easy to go DIY. I won't argue the point if you have the equipment to raise the car safely.
The process requires removing the front wheel, then pulling 3 snaps that hold the cover to the headlight compartment (in the fender well), then pulling the cover off, then removing two #10 torx screws, then unplugging the old light, plugging in new light, putting it all back together. Then repeat for the other side.
Unfortunately, you HAVE to get your head in there to see where those torx screws are to pull them and put them back. W/O a lift (vs a jack) I didn't like the vision of my fat head being squashed between the fender well and a big a... brake rotor if the jack/jackstands topple or collapse. Score one for my Corvette mechanic.
The moral here, is flicker doesn't always = bulb, but in the end if you have to replace the ballast, the bulbs will probably need to also be replaced.
Now on to that fricking clutch...
