Chime when opening door.
Old 12-04-2011, 09:41 AM
Triumph Jerry
Triumph Jerry's Avatar
Default Chime when opening door.
'09 C6 Coupe m6
The car is sitting there locked, I walk up with the fob in my pocket and
open the door. Sometimes it's silent and sometimes I get the chime going off. Bing, bing, bing, bing, bing......
It must be in the manual somewhere, but I can't find it. I can't figure out what it's binging about 'cause everything is the same.
PITA, because I have to hurry up and jump in, close the door to get it to stop.
Old 12-04-2011, 10:41 AM
Snake.Oiler
Support Corvetteforum!
Snake.Oiler's Avatar
St. Jude Donor '13,'14,'15,'16,'18,'19-'20,'22,'24
It should only be dinging if you had left a fob in the car.
Old 12-04-2011, 12:02 PM
Bearsden
Bearsden's Avatar
Mine's an '08 and does the same thing. I usually notice it when I get into it unlocked in the garage. Sometimes it chimes, sometimes it doesn't. No rhyme or reason to it.
Old 12-04-2011, 01:01 PM
RedHottGS
RedHottGS's Avatar
I had this same problem with my 2010 GS until I had the FOB replaced. It was working intermittently, no issues since replacing it.
Old 12-04-2011, 01:19 PM
Torchsport
Torchsport's Avatar
St. Jude Donor '15-'16-'17-‘18-'19-'20-'21-'22-'23-'24
My '11 GS does it once in awhile.
I ignore it.
Old 12-04-2011, 02:00 PM
cclive
cclive's Avatar
The car thinks that a fob is inside the car. This is from the previous time that you exited the car... when you closed the door, you were close enough that the car thought you left the fob inside. It may or may not be that a fob is currently inside the car.
Old 12-04-2011, 02:02 PM
Thrash
Thrash's Avatar
The FOB is such a waste, perfect for the Occupy-Crowd though
Old 12-04-2011, 05:12 PM
2006c6keller
2006c6keller's Avatar
Default Crazy
This bing, bing gets to be "tricky" at times, I've had trouble with wife getting out of the car slowly after I get out and bing goes crazy. Sometimes, NO RHYME OR REASON! ==> Typical Vette.
Old 12-04-2011, 05:48 PM
caroutisine
caroutisine's Avatar
I wish they would just all go back to using keys. All these new cars with their keyless start are such a PITA for multiple reasons. If you have 2 fobs in your pocket, maybe the car your going to use doesn't see the one is should, so it won't work. Well, if I have 2 keys in my pocket, I can pick the right one and start the car. Low battery or other interference "no fob detected" on start or stop. Leave the fob in a coat pocket and put it in the trunk, all of the sudden you're locked out. Go to a car wash and you can't leave the "keys" in the car. Just the fob, well it may lock anyway and not let anyone back in. Go somewhere with someone else in the car that also carries a fob for the same car and stop to get gas or something, well the car still sees the other one in the car when you get out so you get the 3 horn beeps.
I don't understand the logic. "Let's have them push a button because it's such a hassle to put a key in a hole and twist it."
If given the option, I would always get a car with a simple key. But it's not an option for most cars that have the keyless ignition.
edit...Didn't mean to turn this thread into something else. OP, When you get in the car before you close the door (or after) does the DIC say anything? I haven't had this problem with my keyless on the C6, but sometimes the DIC will give a message as to what the car's issue is. "No Fob Detected"...etc. Maybe an interior light is left on or something? May not be related to the keyless ignition.
Old 12-04-2011, 08:17 PM
z06clif
z06clif's Avatar
you may think you exited the same way but you didnt. The car thinks the fobs inside..................silly car
Clif
Old 12-05-2011, 01:34 AM
Triumph Jerry
It says in the manual, if the fob is left inside the horn will blow 3 times.
Old 12-05-2011, 01:36 AM
Triumph Jerry
NEWS FLASH!!!
Just heard that the NEW C7 is going to have a key ignition!!
(everything old is new)
Old 12-05-2011, 01:50 AM
Triumph Jerry
I aways lock my vette in the garage NOW, and told my wife to lock her mustang too.
I was in the garage last week, and went in the house to get something and when I came out this stupid old bass-turd from down the street was sitting in my vette.
He said, "boy this thing is sumthin' else isn't it?"
YOW!! My wife's new mustang was parked right next to it, and he had to open my door and squeeze in!
4thC4at60
4thC4at60's Avatar
Received 2,922 Likes on 1,303 Posts
Originally Posted by Triumph Jerry
NEWS FLASH!!!
Ned Ludd's alive?
Old 12-05-2011, 04:49 AM
CaryBob
CaryBob's Avatar
Only if you choose that option when you personalize.
Old 12-05-2011, 02:12 PM
caroutisine
I think the default is for it to honk 3 times. I need to find that in option and turn the thing off.
Old 12-05-2011, 03:35 PM
CaryBob
CaryBob's Avatar
Jerry, the chime is telling you that the car thinks there was a fob left in the car when the driver's door was last closed.
The horn will only honk three times if you choose that "fob warning" option when you personalize the car for that particular fob. Regardless of whether you turn that option on or off, the car will chime the next time the door is opened.
Try this simple experiment: Turn the engine off and open the driver's door but stay in your seat. Now close the door. Wait five seconds and open the door again.
What is happening is that, when you exit the vehicle normally and close the door, you are close enough to the antenna that the car is receiving a signal from the fob and therefore it thinks the fob is inside the car. The antenna that is causing the issue is probably the door unlock one which is located, I think, near the upper rear portion of the door (the bottom of the halo). About 2 seconds after the door closes, the car tries to sense a fob. If the fob is in your pocket within a few inches of that part of the door at that time, it may sense it and declare a "fob warning". The horn may or may not blow, depending on whether you chose that option, but the chime will sound the next time the door is opened.
I think, anyway.
Old 12-05-2011, 03:57 PM
c6miller
c6miller's Avatar
make sure you press and hold the stop button until the light is solid red before you exit and it should not chime. It will chime if you exited the car with in the accessory position.
To Chime when opening door.
Quick Reply: Chime when opening door.
