** if you own a 2005 read this** column lock issues fix
Old 07-02-2012, 03:43 PM
CWHPARTS
Platinum Supporting Dealership
CWHPARTS's Avatar
Default ** if you own a 2005 read this** column lock issues fix
2005 corvette COLUMN LOCK ELIMINATOR for manual trans cars
fix your 05 column lock problems for $89.95
http://corvettesofhouston.com/248-20...ock-eliminator ORDER HERE
ok we all know about the problems with the C5's and the column lock. for some reason gm decided they keep installing column locks on the 05's even though they were recalling all the c5's for column lock problems.
for years now we have sold our column lock bypass for the C5 we have sold tens of thousands of them. we have had alot of calls for the 2005 column lock issues lately. so we used my 05 to prototype a column lock elimantor to cure this problem. currently the only way to correct the problem is to replace the parts, which put the same troubled parts right back in play. just like on the c5 our column lock eliminator fools the computer into thinking the system is working perfectly even though it has been disabled. this can be done once you have had a problem with your column lock but is highly recommended as a preventive. why wait till your car leaves stranded. install one of these now so you never have to worry about it again.
there are a good bit of threads on here about guys having to disconnect the battery over and over again till it unlocks or simply just have the car towed to a shop for service. this simple plug and play unit will save you all those headaches.
our column lock eliminator is very easy to install all plug and play no cutting or rewiring needed. it is so simple we had one of our techs 9 year old daughter install one. this is the fix all 05 owners have been looking for. we have been testing the unit in my car now for months and we are finally ready to put these into production.
INSTALLATION
IS A SIMPLE AS REMOVING THE TRIM PANEL WITH THE DIC BUTTONS, THEN REMOVE THE 4 BOLTS THAT SECURE THE GUAGE CLUSTER, UNPLUG THE COLUMN LOCK HARNESS AND PLUG IN OUR COLUMN LOCK ELIMINATOR, THEN REASSEMBLE.
every unit will come with detailed instructions and we will be posting the video of the install as well. like i stated before we had a 9 yr old girl install one of these units.
3 YEAR WARRANTY
dealers welcome call for wholesale pricing
install instructions
1. Remove the instrument panel trim
i. Lower the tilt steering column to lowest postion
ii. Pull outward on lower edge of trim panel
iii. Dissconnect eletrical connectors on dic buttons
2. Remove instrument cluster
i. Remove instrument cluster bolts (4)
ii. Move the instrument cluster out of the way
3. Find the black box located on pass. Side of the steering column support bracket (steering column lock module)
4 push the ignition button putting car in accessory mode UNLOCKING THE STEERING COLUMN LOCK
5. Remove the harness from column lock module with blk,orng,pupl,grn wires or later models computer ribbon is used instead of wires
6. Plug the cle into the column lock module
7. Reassemble
install video
http://www.youtube.com/watch?v=umBo8...ature=youtu.be
ORDER HERE http://corvettesofhouston.com/248-20...ock-eliminator
patent pending
__________________
YOUR CORVETTE SUPERSTORE SINCE 1988
CORVETTE WORLD HOUSTON
281-821-1222
http://corvetteworldhouston.com/
Old 07-02-2012, 04:15 PM
gar4403
gar4403's Avatar
Subscribed for more information.
Old 07-02-2012, 04:50 PM
bario
bario's Avatar
Is this for real?
Are these in stock/available now?
I have had no issues yet, but I accept that it is only a matter of time. I would love to hit my '05 with a pre-emptive strike!!!
I was actually about to oder up a new column lock assembly, just to be ready for the day, which will likey be right after GM decides to cease production of that part.
B
Old 07-02-2012, 04:56 PM
BlueOx
BlueOx's Avatar
INSTALLATION
patent pending
Dang, what took you so long? I look forward to seeing the video.
Old 07-02-2012, 05:25 PM
CWHPARTS
CWHPARTS's Avatar
Originally Posted by bario
is this for real?
I have had no issues yet, but i accept that it is only a matter of time. I would love to hit my '05 with a pre-emptive strike!!!
I was actually about to oder up a new column lock assembly, just to be ready for the day, which will likey be right after gm decides to cease production of that part.
B
Originally Posted by blueox
dang, what took you so long? I look forward to seeing the video.
yes these are instock ready to ship
call me to order 1-800-829-6434
we have had a few calls on this from time to time but lately we have been seeing alot more threads about this and getting alot of calls.
Plus i finally said ok on testing these in my personal car
Old 07-02-2012, 11:21 PM
xgto
xgto's Avatar
Extremely interested. do you have a photo of the bypass unit ? This is fully tested and reliable and totally BCM compatible ? ?
Old 07-02-2012, 11:28 PM
xgto
xgto's Avatar
when this bypass is plugged in is there less of a start delay ?
Calling tomorrow to get one.
Old 07-02-2012, 11:35 PM
loudvolvo
loudvolvo's Avatar
would love to see a picture of this piece...how long has it been installed on the test vehicle???? very interested in one..only have 16K on the car but i also accept that its only a matter of time before the column lock crap happens ot me
Old 07-03-2012, 01:40 AM
bario
bario's Avatar
Calling tomorrow!!!
B
Old 07-03-2012, 01:48 AM
AaronDoud
AaronDoud's Avatar
Very interested in this myself since I just got an 05.
Old 07-03-2012, 02:43 AM
debo
debo's Avatar
WOW!! This is great news, now I don't have to worry about this happening anymore. Good Job on developing a product!!!!
Old 07-03-2012, 06:58 AM
JKbride
Support Corvetteforum!
JKbride's Avatar
W. GA Events Coordinator
St. Jude Donor '12-'13-'14-'15
Old 07-03-2012, 07:01 AM
Jimmy C-6
Jimmy C-6's Avatar
Old 07-03-2012, 08:47 AM
yeller z06
yeller z06's Avatar
Seriously? Tens of thousands? Wow.
What is the difference between a column lock bypass and a column lock eliminator? (note the correct spelling)
Seems to me that if you can bypass the problem, no eliminator is needed...
Old 07-03-2012, 09:08 AM
CWHPARTS
CWHPARTS's Avatar
it has been in my car for almost 2 months now. completely compatible with all 05's manual trans cars
no it wont affect that at all
Old 07-03-2012, 09:10 AM
CWHPARTS
CWHPARTS's Avatar
pics and video of install coming soon. it has been installed in my car for almost two months. install takes less than 20 mins.
my car wasnt having a column lock problem but now that the unit is installed it never will.
Old 07-03-2012, 09:17 AM
CWHPARTS
CWHPARTS's Avatar
for the C5 units we sell an average of 15 units a day.
for patent reasons we call the unit for the 2005 COLUMN LOCK ELIMINATOR. it basically does the same thing as the C5 unit.
To ** if you own a 2005 read this** column lock issues fix
Old 07-03-2012, 09:19 AM
xgto
xgto's Avatar
Just placed my order.
Old 07-03-2012, 09:22 AM
CWHPARTS
CWHPARTS's Avatar
thank you
Old 07-03-2012, 09:41 AM
VetteTico
VetteTico's Avatar
I just placed my order too.
Quick Reply: ** if you own a 2005 read this** column lock issues fix
