Installed my splitter!
Old 08-01-2012, 05:40 PM
mabryusmc
mabryusmc's Avatar
Default Installed my splitter!
Hey gents, so I finally got around to putting on the front splitter. Not as bad as I thought it was going to be. It mounts very solid and fits really well. Ground clearance now SUCKS as you can tell by the first photo.... that is how I pull in and out of my driveway! Theres no more than a 1/4 and you have to get it just right or you will scrape... ugh. Sorry for the crappy photos... didnt want to pull out the other camera!
Ill snap some better photos when I get the car on level ground!
Pulling in/out of my driveway-
Old 08-01-2012, 05:58 PM
Tarl
Tarl's Avatar
Looks good. That would be my only concern, scraping all the time. How did it mount? Did it require any drilling? Also is that the OEM color? <--- meaning is that the color the splitter comes when ordered?
Old 08-01-2012, 06:04 PM
mabryusmc
mabryusmc's Avatar
Just like with the sideskirts I did have to drill I drilled the required holes and then between the splitter and the car I put this black foam rubber to guard against any sort of rubbing....
It came in a black primer... I just took a can of black spray paint and put down a couple coats, wet sanded smooth, couple more coats, wet sanded smooth, couple more coats, wet sanded smooth, and then used turtle wax polish. I did the same for my rear diffuser. Its black and has some shine to it but its not glossy... you cant see your reflection in it. Came out really well....
Old 08-01-2012, 06:10 PM
ButWhatDoIKnow
ButWhatDoIKnow's Avatar
Originally Posted by Tarl
Looks good.
Old 08-01-2012, 06:40 PM
CMEGONE
CMEGONE's Avatar
Looks nice. Where did you purchase from? Manufacturer?
Old 08-01-2012, 06:51 PM
ZO ZICK
ZO ZICK's Avatar
Very Nice
Old 08-01-2012, 07:38 PM
dvilin
dvilin's Avatar
Received 7,929 Likes on 4,810 Posts
Looks good.
Old 08-01-2012, 08:11 PM
su8pack1
su8pack1's Avatar
Old 08-01-2012, 09:05 PM
FrankTank
FrankTank's Avatar
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
Looks good but this is why i won't get one, too easy to scrape it and my car is already lowered, even without the splitter my stock splitter scrapes but that is cheap so can easily be replaced.
I just settled for the ZR1 spoiler for now
Old 08-01-2012, 10:13 PM
mabryusmc
mabryusmc's Avatar
I purchased everything form RPI. Everything came out great!
My driveway is THE ONLY reason my vette is still stock height I dont really scrape but Im damn close... around town Im fine.
Old 08-02-2012, 12:29 AM
peter pan
Life Time NCM #2196
Support Corvetteforum!
peter pan's Avatar
Received 1,099 Likes on 810 Posts
Originally Posted by MEXIVETTE
Very Nice
Old 08-02-2012, 06:33 AM
z28koda
z28koda's Avatar
Looks good!
Old 08-02-2012, 08:07 AM
steig
steig's Avatar
Nice job !!!!
Old 08-02-2012, 08:29 AM
tim414
tim414's Avatar
St. Jude Donor '12
Don't those stick out more than the stock spoiler? I've scraped/rubbed my stock one on the pavement multiple times now. I would like to have the aftermarket one, but I would have it broke in no time.
Old 08-02-2012, 11:52 AM
Wayne O
CF Senior Member
Wayne O's Avatar
Good job on the install....it should help with 'stability' and it looks great! That does look like a 'tight fit' in and out of the driveway...be careful. Aero improvements are long overdue on my car but I hope to do them soon. When I get a splitter on the front I'll have to put some risers on my trailer to elevate the front wheels a bit. If not I'm going to hit the splitter tightening the ratchet straps.
Old 08-02-2012, 11:57 AM
0PaulaH
Former Vendor
PaulaH's Avatar
Love the look!! Mine would be all scraped up in no time!!!
Old 08-02-2012, 02:26 PM
brooklync5
brooklync5's Avatar
Looks great but I would be scared of clearance issues.
Old 08-02-2012, 02:36 PM
rmp
rmp's Avatar
Old 08-02-2012, 03:19 PM
FrankTank
FrankTank's Avatar
CI 7-8-9-11 Veteran
they do, I love the way they look , but even harder to avoid scraping
To Installed my splitter!
Quick Reply: Installed my splitter!
