jacking pucks---for what ?
I saw where jacking pucks are a must for jacking up a Corvette so I ordered some. I have an '08 vert. I see where they go etc., but why are they needed ? They go into the frame so why not just put the jack on the frame in the same place as the puck would go ? I guess I'm missing something but I have jacked up cars for years by using the frame and have never had a problem. Besides, a floor jack would go over the puck anyway so why use it ? Someone help me out, please........
Received 2,051 Likes
St. Jude Donor '13
If your jack has a pad that is flat, slightly soft, and proper size for the area on the frame; no need for pucks.
But most jack pads/lift pads will be too big (crushed rockers) or too small (dished-in frame) or too hard (scratched frame = rust).
I use hockey pucks with an eye-bolt that fits into the shipping slot on the frame. Works for me.
I'm thinking they're more for the swing-arm type lifts that might contact your body panels that wrap under the car. I just have a simple floor jack that I'm very careful with.
Former Vendor
We have one of those here at the shop, and with out the pucks we wouldn't be able to lift any of the C5 or C6 cars w/o breaking rockers.
Location: Stafford VA, home of our wolf den. No house break ins to date.
I always carry mine with me.. you never know when something might happen, and the shop you end up in does not have the proper jacking system to lift the car without damage.
The pucks keep your jack pad off the fiberglass rocker panels.
You don't need to 'install' them into the frame of the car. I simply set a used hockey puck on my jack pad when lifting the car.
i have the permanent pucks.put them in and fergetaboutit.no cracked rockers.my friends z06 ad a hole put in the floor and cracked rockers courtesy of a dealer who let a rookie work on his car.
I have the same ones posted above from southerncarparts.com and they work great. They are snap in "leave in" style. Came in real handy when we put my car on the 2post lift to do the exhaust the other day. No contact with any part of the car, just the pucks.
I have the aluminum style ones, but the cheapies are good. I leave them in permanently, with a dab of silicon and they will not fall off. That way, it is impossible for me to forget putting them on before some shop that does not know lifts and breaks.
Better than a Do'oh!
Yes, it is possible to lift the car without pucks if you are careful but it is much less risky to use them and a necessity when dealing with others who don't give a rat's...
