Does the computer in a C6 log top speed driven?
So...I am looking at a new 2012 GS at my local dealer. I am looking at if for the third time in a day, deciding if I want to trade my 09 Vert for it.
Some saleshole comes up to me and said he had it up to 135 and hardly had the throttle down.
I asked him why would he do that to a car with only 82 miles on it? He said he was joking.
Is there a way to check to see if this clown was really joking or not?
Thanks in advance for your answers.
TBM
TBM
Thanks guys...not sure what I am going to do...It's not like I "Need" a new Vette...mine only has 6900 miles on it...
TBM
TBM
Yes, the computer logs top speed. No, you aren't likely to be able to get at it and the SDM records in a continuous loop so it would have been overwritten in the next ignition cycle in any event.
I was hoping it did and the Service guys could let me know...but I guess I'll just have to check the rear tires....
The Consigliere
Received 5,447 Likes
1 Post
I doubt it - not enough memory for that. My understanding is that the SDM constantly monitors a bunch of variables, but only stores them in non-volatile memory when an airbag deployment, near deployment, or some similar near-collision event occurs.
Unless you have a device like the Window Valet installed the top speed probably isn't being recorded anywhere.
CF Senior Member
Effective in 2013, all event data recorders must record the following information:
- Change in forward crash speed
- Maximum change in forward crash speed
- Time from beginning of crash at which the maximum change in forward crash speed occurs
- Speed vehicle was traveling
- Percentage of engine throttle, percentage full (how far the accelerator pedal was pressed)
- Whether or not brake was applied
- Ignition cycle (number of power cycles applied to the EDR) at the time of the crash
- Ignition cycle (number of power cycles applied to the EDR) when the EDR data were downloaded
- Whether or not driver was using safety belt
- Whether or not frontal airbag warning lamp was on
- Driver frontal airbag deployment: time to deploy for a single stage airbag, or time to first stage deployment for a multistage airbag
- Right front passenger frontal airbag deployment: time to deploy for a single stage airbag, or time to first stage deployment for a multistage airbag
- Number of crash events
- Time between first two crash events, if applicable
- Whether or not EDR completed recording
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03,'04,'05,'07,08,'09,'10,’17
You are missing the most imPOtent lesson of all.
Do NOT go to car dealerships for entertainment. Go to car dealerships only when you are ready to buy. Otherwise, go to a movie theater. It's much cheaper.
Going to a car dealership when you are bored is a bad idea.
