outside temperature sensor stuck on 75 degrees
Old 10-22-2012, 04:28 PM
MarkDFW
MarkDFW's Avatar
Default outside temperature sensor stuck on 75 degrees
Outside air temp sensor has been stuck on 75 for a while. Doesn't matter what the outside temp is, it will show 75. I actually took the car through a touch free car wash a few weeks ago, and it dropped to about 23 below zero. It was funny for a minute, until I tried to turn my AC back on for the drive home, and I couldn't get cold air! Thankfully, it went back to showing 75 all the time in them morning and it remains on 75 today.
Do I just need to replace the sensor or could there be a larger issue that is common that other people know of?
Old 10-22-2012, 04:55 PM
C8gman
C8gman's Avatar
Take a look here and try the 3 buttons simultaneously trick
http://forums.corvetteforum.com/c6-c...eset-it-2.html
Old 10-22-2012, 06:23 PM
MarkDFW
MarkDFW's Avatar
Gave it a try and it didn't work. I am guessing it is either broken and needs to be replaced or there is another issue with having the correct reading get sent to me.
Old 04-22-2014, 09:41 PM
Petrolburner
Petrolburner's Avatar
Any luck? I'm in the same boat and the 3 button combo doesn't reset it.
Old 04-22-2014, 09:48 PM
MarkDFW
MarkDFW's Avatar
I had to have it replaced.
Old 04-22-2014, 09:50 PM
COMMANDER2OOO
COMMANDER2OOO's Avatar
2017 Corvette of Year Finalist
2016 C5 of Year Finalist
I had the same problem when I first bought my vette I replaced the sensor an no more problem
Old 04-25-2014, 07:35 PM
Petrolburner
Where is the sensor located exactly? I may have forgotten to reconnect it when doing the radiator swap.
Old 04-26-2014, 12:45 AM
Petrolburner
Disregard. At one point in the swap I was planning to take out the big plastic shroud in the front and disconnected the air temp sensor. Forgot to plug it back in.
To outside temperature sensor stuck on 75 degrees
Quick Reply: outside temperature sensor stuck on 75 degrees
