Catch can recommendation?
Old 01-30-2013, 04:03 PM
Pittcorvette
Pittcorvette's Avatar
Default Catch can recommendation?
Which catch can do u recommend?
Old 01-30-2013, 04:13 PM
Racer's Avatar
Cruise-In III Veteran
St. Jude Donor '11
None, ask Callaway what catch can they use on their 150,000 mile 660 hp car that has been drag raced, road raced, tracked driven in super hot and super cold conditions and it has never been stronger.
Old 01-30-2013, 04:21 PM
carpe dm
carpe dm's Avatar
Racer, please change that avatar.... have you no mercy? BTW, he is probably right, but I finally gave in the the urge to "do something" and installed an Elite Eng. can. Looks nice.......
Old 01-30-2013, 04:39 PM
Wayne O
CF Senior Member
Support Corvetteforum!
Wayne O's Avatar
Unless your car sees some serious hard track time I don't think a catch-can is necessary. That being said I recommend the Elite Engineerinv catch-can. It's well made, it works well and I especially like that they include all the pieces-parts necessary to install it.
Old 01-30-2013, 05:17 PM
Pittcorvette
I had a 2009 Dodge R/T, and I added the catch can. I was extremely suprised at each oil change how much oil the catch can caught. I know they are totally different engines but I would like to protect my engine as much as possible. I will not track time the car but it gets extremely hot, (over 100 degrees on a daily basis) in my home town, and id like to consider that harsh environments for the engine. Thank you response. One question was the install pretty easy?
Old 01-30-2013, 05:51 PM
cdanick
Cruising
cdanick's Avatar
We have an Elite Engineering Black Chrome Catch Can on our 2008 Z51 and have just ordered an Elite Engineering Black Chrome Catch Can for our 2013 Grand Sport.
The 2008 Z51 is mostly driven around town lately and had about 1/3 of the catch can filled
with oil.
Old 01-30-2013, 05:55 PM
azc62006
azc62006's Avatar
Default catch can
i changed my intake last year. when i took it off the plenum was wet with oil.i dont think that is good for fuel and air to mix with? i put a catch can on. it cant hurt!
Old 01-30-2013, 06:56 PM
Knob Jockey
Knob Jockey's Avatar
St. Jude Donor '11-'12-'13-'14-'15
My Elite Engineering catch can is about half full at the annual oil change.
My car's not a DD obviously, and it gets no time on the track.
Old 01-30-2013, 07:25 PM
Spark 2
Spark 2's Avatar
St. Jude Donor '07-'08-'09
I like the size (dimensions), design, and the performance of the AMW
catch can.
AMW (Accurate Machine Works) www.accmachtech.com
Old 01-30-2013, 07:30 PM
FRChilln
FRChilln's Avatar
I have an LG which works just as good as any other but I would go with an Elite one just because it looks the cleanest to me.
Old 01-30-2013, 07:31 PM
hawkandersonjr
hawkandersonjr's Avatar
Location: US-ARMY 1974-1996 Retired ; Oklahoma, City ; Atlanta, Ga: Hephzibah, Ga
Can someone clue me in on the purpose oil catch can. I don’t see one on mine and I am wondering where is this oil going. It is a 05 DD.
Old 01-30-2013, 07:32 PM
JW Motorsports
Banned Scam/Spammer
JW Motorsports's Avatar
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
RX gets our vote
Old 01-30-2013, 07:37 PM
FRChilln
FRChilln's Avatar
It catches blow by oil on hard accelerations from going into your intake manifold. You usually get about 3 ounces per track use or 2-3 ounces per oil change. Great satisfactory every time you see what's not going into your mani. Cheap fun 15min mod.
Old 01-30-2013, 08:16 PM
Mike's LS3
Mike's LS3's Avatar
It actually catches oil vapor on decel, especially after a WOT run. Vacuum is at its highest point on high rpm decel which pulls oil vapor from under the intake valley port into the throttle body port. Oil vapor degrades the octane in fuel which can cause detonation and trigger the knock sensors reducing hp.
BTW: I have an Elite Engineering catch can that works well and is a quality product.
Old 01-30-2013, 08:32 PM
laconiajack
laconiajack's Avatar
Oil catch cans eliminate upper cylinder lubrication which extends engine life. If the OEM engineers thought it a vital function to eliminate this lubrication they would have spent a couple of bucks to include it on their engines. But they didn't, meaning it is a totally useless accessory.
Old 01-30-2013, 09:54 PM
Glock 23C
Glock 23C's Avatar
I have been contemplating this mod for my LS1. Thx for the no non-sense explanation on why it is not on the original motor.
Old 01-31-2013, 11:09 AM
FRChilln
FRChilln's Avatar
Correct it prolly wont make or break your engine but it obviously catches oil so I wouldn't call it totally useless. I think GM just left it off because they don't want to be held liable for people not properly draining it occasionally.
To Catch can recommendation?
Old 01-31-2013, 01:39 PM
Bedouin
Bedouin's Avatar
Mike'sLS3 nailed it...detonation, knock retard/sensors, etc. & the EE catch can is a quality piece with an easy emptying process of simply unscrewing the lower catch can & dumping it. I'm 100% satisfied w/ mine & read a thorough CC comparison/review before buying it.
My '12 GS LS3 intake literally had a pool of oil in it, not to mention the sooty globs of oil blow-by all over the back of the car, burnt onto the tail pipes, & obviously now in the exhaust, cats, etc. GM runs these oil vapors into the intake purely for emissions & it's not good for the engine.
Just take a look into your intake manifold w/ a flashlight & it will tell you all you need to know..I've emptied a teaspoon of oil out after each of my last 3 drives. The EE can installs simply & in minutes & I wish I'd installed it from the beginning.
Old 01-31-2013, 05:51 PM
SUB VETTE
SUBVETTE
SUB VETTE's Avatar
Burning the oil that enters your intake manifold without a catch can leads to carbon buildup on your piston tops which in turn, over time, leads to hot spots, detonation and timing pulls by your ECM. Efficient catch cans eliminate most of that oil. I've been running an Elite can for five years or more now and have been well satisfied.
Old 01-31-2013, 06:37 PM
Mike's LS3
Mike's LS3's Avatar
Forgot to mention carbon buildup in my post, excellent point
Quick Reply: Catch can recommendation?
