C6 Grandsport Rain and Cold Weather Tire?
I replaced a BMW M3 with a 2012Centennial Grand Sport and I am terribly disappointed with the stock Goodyear Eagle F1 Supercar G2 tires as they are downright dangerous in anything but warm, dry weather. If the temperature drops to the low 40s , or the roads are wet, they have no traction!
In the forums, Grandsport and Z06 owners curse these tires and assert that they will be getting rid of them but what is a good replacement tire? I would never drive the car in snow or ice but I would like to drive it in the Pennsylvannia ealy Spring and Fall.
Can anyone suggest a better tire for rain and cooler temperatures that will suit a C6 Grand Sport?
The stock tires are Summer Performance tires and not meant for Winter driving. You have to be really careful. You should not even drive them under 20.
There are several all season tires out there. Michelin's seem to get high ratings on here...
Welcome to the forum!
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Actually you are one step ahead if you have the g2's... The gen 1 tires seem even worse in the cold. You may want to consider the Michelin pilot super sport (PSS) or the Bridgestone but none are all-season tires.
You bought a car that is safe only in warm, dry conditions due to it's summer performance shallow tread tires, and the fact that no alternative replacement tires currently exist that fits it. Hopefully all-season run-flat replacement tires that last three to four times longer may become available in coming months. In the meantime keep her garaged.
We are getting ready to order the Bridgestone Potenza RE050A RF. We had read on this forum about them saying they were a pretty good tire. We also have a C6 Grand Sport.
Best price we've seen for these is on Tirerack.com
Received 1,596 Likes
Why do these questions keep coming up ? It is a high performance car with summer performance tires. It will not handle well in the rain, snow, cold etc. With that said, I have driven my 13 GS in all of the above conditions and only the snow was no go.(Literaly) The car can be driven in the above conditions, but not like it would be if it was 85 and sunny. Use your head and don't drive like your hair is on fire and you WILL BE OK.
What about Nitto Invo's?? They have high ratings in the wet, are rated quieter, and more comfortable that the GY's..
They are also $1400 installed at Discount Tire..
Maybe they don't have the sheer performance of the GY's or Michelin's, and they are not run flats, but should they be considered as alternatives??
Opinions?
Opinions?
I've driven my 13' GS in every thing, even tried snow for fun; but the best thing you can do is get the PFDAT alignment and be careful with the throttle in the lower gears.
It was 28 degrees this morning in my part of Florida, and is supposed to be colder tomorrow morning. Incidentally, the tires held very well (as they always have), and I did the usual 3/4 throttle romp, to get to the interstate speeds through the gears, with no spinning whatsoever.
NOTE - When I had the original GEN2 tires, I could do the same thing when they were new, but not 15k miles later (as I'm doing today with the Bridgestones). I would be spinning in 3rd with the Goodyears, which was why I went to the Bridgestones before they Goodyears were fully worn out.
The Bridgestones also hold well on wet roads, I routinely drive safely with all traffic in some very heavy Florida rains.
I've driven my vette to WV when the temps have been in the teens, but I time the trips so that I don't hit snows. I've never had any traction issues there either. Granted, I'm not drag or road racing in these temps, but I could still accellerate/handle better than practically any other vehicle on the road then, if I chose to do so.
Not to highjack the thread, but here is some other dry sump vette info about my trip to work this morning at 5:20 am. The garage was about 50 degrees, and the DIC confirmed it with water and oil temps at 47 degrees. The HVAC outside air temp read 48 degrees. Tire pressures were 29 fronts and 28 for the rears.
When I backed out of the garage and started the 2 mile drive (at 30 mph) out of the neighborhood, the outside air temp quickly dropped to 27 - 28, and the water temp steadily rose to 145 degrees, at the end of the 2 mile slow drive to the interstate. Oil temp was 60 degrees. Yes, 60 degrees, it's nothing abmormal, with the dry sump it is a LOT of oil to warm up. After 2 miles of driving in the dark, tire pressures were still the same.
Then, to get onto the interstate, there is no accelleration lane, so I have to find a hole in the traffic and punch it, which I do daily with the vette. I normally take off here in 2nd, so that I can swing the sweeping turn on the interstate crossover without worry of spinning, and even in the sub 30 temps, I hit my normal 60 mph in 2nd with no issues. Grabbed 3rd, got up to the high 70's cruising speed, then worked my way to 6th.
Finally, when I finished the approx. 10 mile drive and pulled into work, I checked the temps again. Outside air was still 28 degrees on the HVAC, the front tires had increased 1 psi to 30 both fronts and 29/30 on the rears, the water temp was 192, and the oil temp was 83 degrees. YES, 83 degrees.
Congrats and welcome!!! If I get caught in the rain I never go over 55mph. with the GY tires. At some point this year I will be switching to the Bridgestones ...
http://www.tirerack.com/tires/tires....oModClar=Coupe
These are your choices for matched sets,GS tires....
http://www.tirerack.com/tires/TireSe...=58165&tab=All
I agree there are better wet weather tires available, though.
No comment on cold, however - we don't allow that here.
My drive into work this morning was 19 degrees.
Roads were dry.
My '13 GS is my daily driver here in Raleigh.
It stays home in snow or ice, but goes out in everything else.
Michelin Super Sports are the way to go. My Corvette isn't a moving chicane in the rain any more and it is fantastic in the cold, even real cold such as 8 degrees or so. Not a run flat so you have to throw the dice on the .0001% chance you'll get a blowout. I rather throw the dice on that then driving with crappy Goodyears in the rain/below 40.
Welcome to the Corvette world. Regardless of what tire you have or even driving temps/conditions the Corvette can be a handful if not driven with common sense. There seems to be a lot of "my back end came around" stories. Generally it comes down to driver error in the end as they were probably driving too fast for conditions (includes tire performance) or gave it too much throttle for conditions.
