Old Mar 5, 2015, 07:10 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Steering and Suspension How-Tos
Print Wikipost
How to remove rear sway bar
Old Apr 14, 2013 | 09:31 AM
AtomicZ_Eric's Avatar
AtomicZ_Eric
Default How to remove rear sway bar
Hello forum members. I've purchased a Borla over the axle exhaust for my Z06. Borla's directions instruct me to:
1) Remove the top two bolts and bottom two nuts securing the anti-sway bar leaving the bottom bolts which run through the lower control arm in place.
2) Swing the anti-sway bar down and out of the way.
I see the car pictured in the directions is on a 4 post type lift (i.e. wheels on the "ground" and the suspension compressed). My question / dilemma:
If my car is sitting on jack stands with the suspension in "full droop" is the sway bar able to be easily swung down and out of the way and put back on?.... Or does the suspension need to stay in a compressed stated?
Thanks in advance for your help.
Old Apr 14, 2013 | 09:39 AM
wayback's Avatar
wayback
When my sways were replaced the car was on a lift, full droop.
I also changed the sway bar bushings on the 85 using jack stands with no problems(removed the sways) . You should be OK.
Old Apr 14, 2013 | 09:48 AM
etaylor14's Avatar
etaylor14
if the suspension is hanging the sway bar is unloaded and will come right down.
Old Apr 14, 2013 | 10:46 AM
AtomicZ_Eric
Awesome. Thanks for the replies.
To How to remove rear sway bar
