Question on NAV system route types.
I have a 2013 with NAV and would like to know what the "Normal" route is. It always gives me the option of 3 different routes - Quickest, Normal, and Shortest. What is the "Normal" route based on and how does it calculate it?
Thanks,
Dennis
Thanks,
Dennis
Looked it up in Pauls tutorial. He suggests as a general rule to use "normal", however it doesn't state why criteria the computer uses in formulating the different routes.
Received 2,051 Likes
St. Jude Donor '13
No scientific study, but Normal seems to use major roads/Interstates as it's primary choice when available.
I usually have the NAV preferences set to avoid major highways and often use Quickest for the route to a destination and the Normal for the return route -- especially if I'm not in a hurry to get back. The change in scenery is enjoyable, and as you say, the Normal perhaps takes a few less different roads (more main roads?) than Quickest.
If I'm taking a major trip I'll exclusively select "Use major highways" and the Quickest route -- "Normal" seems to be a bit more unpredictable on those occasions (when I want to minimize travel time).
Race Car Tech
I have only "major highways" selected, and use Quickest Route for the majority of the time. I always do a Route Preview in 1/2 mile scale just to be sure that it takes me on the highways that I want to go on.
If it doesn't then I'll make adjustments as required to the quickest route, or re-select either normal or shortest route rather than quickest.
I use Quick 99% of the time. Just thinking about how I would write the software:
Short is easy - take an alley if it is shorter than going around on the Interstate. I have confirmed that this is pretty much what it does. This is often the slowest but typically uses less gas.
Quick would check the speed limits and take the back road only if it was long enough to overcome the slower speed than the Interstate. This works well for people who drive the speed limit but I sometimes deviate because I don't.
Normal takes the Interstate if possible since that is where most people go.
But all fo that is just a guess.
