Grand sport
Grand sport
Has anyone ever had a noise coming from their dashboard like the sound when your speakers are busted but the radio not on went to work this morning didn't have any issues got off this evening that's when it started.
Received 1,597 Likes
If it is only on startup and goes away it could be the head unit. Every now and again it sounds like the CD/Nav disc is loading or resetting itself.
No it wasn't making that noise while I was driving to work it started when I was driving home I thought my speakers were going bad but when I turned off the radio I could still here it every now and then sounds like something vibrating in the dashboard.
That stinks, how cold is it where you are ? Contraction of some of the dash panels maybe ?
If it is happening when driving down the road, it could be the piece of plastic that is at the bottom of the windshield, or a missing clip.
This thread describes it, there are lots of other posts out here about it too. https://www.corvetteforum.com/forums...l-problem.html
It will be covered as a warranty repair, if you are still under warranty.
My noise was the rear dirver side speaker grill... Radio on or off, it would make noise and it was hard to decide just where is the noise coming from. This noise also would stop after 4 to 5 miles.
Also, there was / is a recall to replace the plastic strip at the outside bottom of the windshild due to vibration. That may be your problem! Mine was not causing an issue but I had it replaced anyway.
MK
MK
