Front or Back-Up Camera Install for a C6
Old 02-02-2015, 09:15 PM
BurgundyVette
BurgundyVette's Avatar
Default Front or Back-Up Camera Install for a C6
I purchased a DNX-771 HD Kenwood radio. Has anyone installed a back-up camera or front camera, with this unit? Or has anyone, installed a camera period. If so, describe the installation process.
Old 02-02-2015, 09:30 PM
Tombovette
Tombovette's Avatar
Default Back-up Cam
Might want to post this in the Audio/Electronics Forum. Lots of good info over there on Cam install.
Old 02-02-2015, 10:12 PM
COMMANDER2OOO
COMMANDER2OOO's Avatar
2017 Corvette of Year Finalist
2016 C5 of Year Finalist
I also have a kenwood deck an installed both front an rear cams along with xm satilite antenna. what exactly do u want to know?
Old 02-03-2015, 01:45 AM
Dano523
Dano523's Avatar
Received 3,019 Likes on 2,175 Posts
Both will plug into the back of the deck.
On the reverse camera, going to tie the trigger wire for the reverse camera into the back up lights (positive side).
When you put the car into reverse, the back up lights come on to trigger the head unit to switch the display over to the back up camera.
As for mounting location of the back up camera, there are types that will mount to the top of the license plate bracket, as well as smaller units that you can mount to the flat above the licenses plate.
On the front camera, all depend what you want to use it for, which will dictate it mounting location.
Old 02-03-2015, 08:31 AM
4SUMERZ
Race Car Tech
Support Corvetteforum!
4SUMERZ's Avatar
Received 2,320 Likes on 1,664 Posts
As someone else mentioned, you can mount your front or rear camera anywhere. You pick your power source for the camera, and once the camera is powered up, it opens the video feed for the monitor, or your Kenwwod unit.
Most people use the back up lights as the back up camera power source.
I installed a front facing camera to protect the front end from curbs. I mounted it on top of the center air dam, using the existing bolt, just below the radiator, and I power it from my Fog lights, which I seldom use otherwise.
You can install a switch in the cockpit for the front camera if that's what you want to do.
Here is a pic of my front camera location, and where my monitor is located.
Old 02-03-2015, 09:58 AM
ben dover
ben dover's Avatar
Location: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23-'24
Nice setup.
To Front or Back-Up Camera Install for a C6
Quick Reply: Front or Back-Up Camera Install for a C6
