what's going on?
Old 02-19-2015, 04:06 PM
Pho Nguyen
7th Gear
Pho Nguyen's Avatar
Default what's going on?
I just replaced the shocks on my C 6 Corvette with some regular Blistein shocks. My car originally had the z51 package and I replaced the shocks with non magnetic ride shocks. Now my car flashes "shocks inoperable " and car shuts off at 80 mph. How do I bypass the system or fix it to drive normal again?
Old 02-19-2015, 06:38 PM
Russkier
Russkier's Avatar
I think they make something to emulate the shocks like there still hooked up. They are not too expensive.
Old 02-19-2015, 06:49 PM
RJRSW
RJRSW's Avatar
The Z51 option did not include magnetic ride shocks just a stiffer version of the standard shock with stiffer sway bars and bushings.
The magnetic ride option with the special magnetic shocks was F55. As was already stated there is a fix available to turn off the warnings when magnetic shocks are replaced with standard shocks.
Why did you change out the mag ride shocks? They are very dependable and it is rare that they fail.
Old 02-19-2015, 09:35 PM
COMMANDER2OOO
COMMANDER2OOO's Avatar
2017 Corvette of Year Finalist
2016 C5 of Year Finalist
I bought my car with after market shocks installed but suspension inop light always came on along with the do not exceed 80 mph light. I took the car to a chevy dealer told them what was goin on an a tech two programmer removed both warnings with his computer free of charge an took less then 5 mins to do. u might want to try that.
Old 02-19-2015, 09:55 PM
Mad*Max
Mad*Max's Avatar
Received 1,500 Likes on 817 Posts
you can get it reprogrammed so that the car will ignore the shocks, another member here had it done on his car
Old 02-19-2015, 10:54 PM
Pho Nguyen
7th Gear
Pho Nguyen's Avatar
The shocks were bleeding and the car was riding pretty rough. I replaced them with adjustable shocks.
Old 02-20-2015, 12:54 AM
Cyber Grey
Cyber Grey's Avatar
What did you do with mag shocks???
Old 02-20-2015, 01:38 AM
Pho Nguyen
7th Gear
Pho Nguyen's Avatar
Default mag shocks
my mechanic threw them away I think. Why?
Old 02-20-2015, 01:40 AM
Pho Nguyen
7th Gear
Pho Nguyen's Avatar
I tried doing that. The dealership says it's a liability issue and refused.
Old 02-20-2015, 08:21 AM
RaysLilVette
RaysLilVette's Avatar
When i was shopping for a vette, i always refused to get one with the F55 package. It is great when the car is new but when you buy used with 60-70K there more then less will have to be changed out soon. I had a 99 C5 that had the magnetic ride, When the shocks started going out i got a quote on how much it was to change the magnetic shocks and it was 3K from the dealer (I lost it). I opted to just change them out for Z06 shocks, but that was a hassle cause of the reprogramming and having to find away around the shock sensor. I just ended up selling the whole car and getting a C6 (Without magnetic ride). Good luck, i would search the forum i know there are a lot of DIY things you can do with that.
Old 02-20-2015, 08:40 AM
Elizabeth City Vette
Elizabeth City Vette's Avatar
I had a 2004 with the F55 option and got the leaky shocks replacement cost estimate. $1600 for the 2 front shocks. Replaced all 4 with the Z06 shocks and took the car to a mechanic with a TECH II and he programed the F55 option out of the computer and no more errors or limits. Total cost was $450 for all 4 shocks, labor to install and reprograming the computer. I got the shocks from Gene Culley.
Old 02-20-2015, 08:42 AM
Boomer111
Boomer111's Avatar
Read through this.
Find a GM tuner in your area. Speciality shop.
https://www.corvetteforum.com/forums...imulators.html
Old 02-20-2015, 01:32 PM
CMY SIX
CMY SIX's Avatar
nothing like knowing what you bought, are you sure it's a corvette?
Old 02-20-2015, 05:39 PM
COMMANDER2OOO
wow unbelievable, I live in a small town an I knew the crapy dealership in my town a: wouldn't know how, or b: would tell me some crap like that. so I went on over to the big city an found a large dealership that had no problem doing the fix .
Old 02-22-2015, 01:28 AM
Pho Nguyen
7th Gear
Pho Nguyen's Avatar
Default I don't know
I'm think it a vette? Oh damn it's a mustang
Old 02-22-2015, 09:31 AM
Rogers 07
Rogers 07's Avatar
http://www.ecklerscorvette.com/corve...2005-2012.html
You need these to make the computer think the shocks are working properly !
To what's going on?
Quick Reply: what's going on?
