2012 grand sport spoiler question
I'm thinking about buying this 2012 grand sport but I do not like the spoiler it is doubled sided taped down if I remove it should I expect to see a small stock spoiler or is that removed when the other spoiler is installed hopefully you understand what I'm trying to say
thanks
thanks
Stock spoiler is removed when anything other spoiler is installed. Stock spoilers should be easy to find, lots are taken off for upgrades.
Are you sure this one is just taped?
spoiler
per the dealership, it is taped down. again its the dealership talking... is that style normally bolted/screwed down ?
thanks
Could try to negotiate with the dealer, make it part of the deal, they take off that spoiler and install a stock one before you take delivery. Then if it is bolted, the surprise is on them. Just sayin'.
Received 3,659 Likes
2016 C6 of Year Finalist
Not always true. I don't remember which manufacture makes it, but there is one that makes a spoiler that goes over the stock one. With that said, this one could be removed and a ZR1 or Chevy full length could be installed in its place.
If you find a good Grand Sport for a good price, I wouldn't even bother arguing minutiae. I don't think the dealer would be open to negotiating down because of it either.
Looked at the car on-line and here's my thoughts:
The car is very clean...inside and out. The yellow calipers look great. The front GS splitter is missing. The rear spoiler could be replaced with a full width spoiler if it's been drilled. The price is OK for the condition and miles.
Me? I would negotiate a price and then insist the front spoiler (and mounting bolts) gets thrown in (do you have the skills to mount?) and negotiate a deep discount for a painted, full width rear spoiler.
Just me.
If the CHMSL is built into that spoiler, then the factory lip spoiler was probably removed before installation. Although two sided tape is removable, I would caution you, that you should first ask that the spoiler be removed and if any paint damage exists, it should be corrected to your satisfaction to complete the purchase. even removing a GM spoiler will leave marks on the paint. So, if you want that spoiler off, do it before you take her home. the seller may not wish to bother to take it off, and would rather sell to someone with less objection.... my .02
They dropped the price to 40k. It has the two roof panels
What's a new front splitter worth ? I have no issues replacing parts , I'm always working on something
Thanks for all the info. Forum people are the best
Ask Gene at Cultrag to run a VIS for you.
spoiler
when you say an easy fix , other than doing some body work for the bolt holes what do I do ? maybe I'm missing something but if you "Bolt" down the spoiler didn't you drill through the body of the car ? as for the 3 hour drive, I commute a 100 miles a day I just wanted to minimize seat time . but sometimes you got to commit
If you have the chance, take the two inside tail light out (1 screw ea) and look up inside and see if they drilled any holes through the bumper to mount the spoiler on this corvette. There will be holes from the stock small spoiler. Even with two sided tape, they may have drilled holes. I have not seen a spoiler like that one on any corvette.
