Question regarding OBDII port
Old 05-17-2016, 12:36 AM
LifeInAVette
LifeInAVette's Avatar
Default Question regarding OBDII port
I know the port is under the steering column on the bottom of the kick panel / lower dash. My question is whether it is supposed to move around. My OBDII port seems to "float" a few centimeters left right forward backward, and I wanted to make sure it's supposed to do that. Every other car I've owned or seen the OBDII port is stable as can be. Are there screws I should look for to make sure the port is "mounted" how it's supposed to be? Or should I take it in for service before my warranty runs out?
Thanks!
Old 05-17-2016, 02:27 AM
CSTYLE
CSTYLE's Avatar
Thanks!
I just push the tabs back in on the side of the port.
LifeInAVette (05-17-2016)
Old 05-17-2016, 09:35 AM
LifeInAVette
Thanks I'll take a closer look and see if the tabs came loose.
Old 05-17-2016, 07:40 PM
Cherokee Nation
Cherokee Nation's Avatar
I think that is normal! Both my 07 and my 08 did the same and I hardly ever used it..
Old 05-18-2016, 11:48 AM
Hells
Hells's Avatar
St. Jude Donor '08
I use mine at least 10 times a week. A little bit of movement is normal.
Old 05-18-2016, 01:47 PM
cclive
cclive's Avatar
A little movement is normal. I attached a three foot extension cord to the port so that it would be easier to get to and anything I plug in will not be kicked when I drive.
To Question regarding OBDII port
Quick Reply: Question regarding OBDII port
