rear differantial ratios
Received 3,088 Likes
2021 C6 of the Year Finalist - Modified
Topdown12 (01-17-2017)
Pro Mechanic
Received 3,952 Likes
Manual trans. has 3.42 rear axle ratio
Auto trans. has either 2.56 or 2.73 ratio depending upon additional options
Check the RPO codes in the glove box. If it shows GU2, you have 2.73 gears; if not, you have 2.56's. GU2 was part of the Z51 option for '08 and '09. It was also a stand-alone option for those two years, as well.
