[ZR1] 1000hp ZR1 build
Mod list:
2'' stainless steel american racing headers w/o cats
5'' custom KP Racing intake
Ported LPE supercharger snout
2.3 upper pulley
14% drive pulley
Aluminum radiator
D3PE heat exchanger
Snow dual nozzle meth kit
Brian Tooley stage 3 cam
Ported Mast black label heads
Ported blower upper and lower case
108mm Southways throttle body
ID 1300cc injectors
DSteck E85 flex kit
McLeod RXT 1200hp clutch
ARP head studs
Fore Innovation stage 3 fuel system
Nitrous Outlet blower plate system
Dual 10lb bottles w/ billet heater bracket
LNC 2001 launch controller
I know I'm forgetting a few things here and there but you get the idea.
Yeah it'll be ready for 2K. I made sure get started in plenty of time so we're not rushing at the last minute. Going to run the 1/2 mile that Thursday. I'll put a MT 345 on when I wear these out, which shouldn't take long!
I don't plan on spraying in 1st or 2nd gear so it should be fine. We shall see.
Greg I'm gonna take a swing at the 179 number! I may not have enough cam though, the lift is pretty conservative. I really like the BTR 3 that came in it so my plan was to see how she did before changing it to something a little bigger. I want to keep the car streetable to cruise on though.
Yeah you and Morris are making a lot of steam on the LSX block! I'm going to try and go the opposite route and shred weight. I might even go as far as pulling the magnetic ride and big brakes later...
Good luck! With 800+ you should be right there.
Thanks! Are you and Marshall planning on making it down next month?
Seats, some sound deadener, Halltech / Katech have some nice light weight CF pieces. Not sure if they still produce them though.
