C6 Corvettes for Sale Private Classifieds, Used C6 Corvettes For Sale, and Modified or Stock Corvettes
F/S Custom Twin Turbo C6
Old 05-29-2016, 01:06 AM
2turboc6
2turboc6's Avatar
Default F/S Custom Twin Turbo C6 840rwhp
Selling my 2006 custom twin turbo c6, clean carfax and title, the car has 88k miles, mostly highway miles before the build, the build has less than 3k miles on it. The car is clean and works perfectly and can be used as a daily driver. The only reason I’m selling the car is that I’m getting married soon and need the money. The car has a Z06 wide body rear panels, and carbon fiber ZR1 front fenders, has a carbon fiber spoiler. Car made 840rwhp on 14psi, and 770rwhp on 13psi, it is currently on 13psi.
Modifications:
6.0 iron block (good for 1200rwhp)
weisco 4.030 custom turbo pistons -10cc
Molnar turbo Billet specfic rods
Callies crank
coated Trimetal main/rod Bearings
Ls9 head gaskets
LS9 lifters
ARP main and heads studs
Melling HV oil pump
Double timing chain
Custom turbo cam
ATI balancer with ARP crank bolt
Iridum spark plugs
Boost a pump
frpp 96# injectors
2Bar map sensor
243 heads .
competition valve job
new Guides
stainless intake valves
Inconel Exhaust valves
Pac 1206X duel springs
ti retainers
Manton custom 3/8 .120 wall pushrods
AC delco compressor, expansion valve, manifold hose and condensor
Alky control twin nozzel Meth injection kit
Custom built turbo kit (built by FIT Fabrication in phoenix)
2x 64mm garret ball bearing turbos p trim 0.48 AR ehxaust housing (rated at 70#/min)
Spraying Nitrous (100 shots) on turbos for faster spool till 7 psi and then disconnects. 15 lbs nitrous bottle mounted in the rear.
Mcleod RXT twin disc clutch
Mcleod Billet Steel flywheel
clutch and flywheel Balanced
new slave cylinder ,new Master cylinder
Asking $30,000, for more information please text 9706913876 or PM. Car is located in Tempe, AZ
Old 05-30-2016, 02:26 PM
Raazor
Goon Squad King of Battle
Support Corvetteforum!
Raazor's Avatar
St. Jude Donor '08-'09-'10-'11-'12-'13x3- '14-'15-'16-'17-'18-'19-'20-'21-'22-'23
good luck!
Old 05-30-2016, 02:30 PM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
good luck
2turboc6 (05-30-2016)
Old 05-31-2016, 11:19 AM
2turboc6
2turboc6's Avatar
bump
Old 05-31-2016, 05:52 PM
ScalaRRthu
ScalaRRthu's Avatar
Looks like an amazing car! Is it safe to say there are no aftermarket hoods available that could cover the turbos?
Also, do you only use the nitrous when racing? How does the car drive when not relying on the nitrous to spool the turbos? Thanks!
Old 06-01-2016, 01:23 AM
2turboc6
2turboc6's Avatar
thanks! I believe a cowl hood would work but I havent looked into it because I like how it looks now. I race without the nitrous, I have tried using the nitrous a couple of times but not racing,it spools super fast without, I can text you a video of a race without nitrous if you would send me your #.
Old 06-01-2016, 08:03 AM
ghall
ghall's Avatar
sigh....Good Luck!!!
Old 06-01-2016, 11:07 AM
sublime1996525
sublime1996525's Avatar
Well that is unique and different.
Old 06-01-2016, 10:53 PM
2turboc6
2turboc6's Avatar
any offers?
Old 06-19-2016, 12:46 AM
2turboc6
2turboc6's Avatar
bump for price drop
Old 06-26-2016, 11:01 AM
KY_C5
KY_C5's Avatar
Hey bro Text me at (502)415-5214 if you could please about car.
Old 06-27-2016, 08:39 PM
OAG
Cruising
OAG's Avatar
Originally Posted by 2turboc6
bump for price drop
Any pics of underside?
Old 07-03-2016, 07:05 AM
2turboc6
2turboc6's Avatar
bump
Old 07-08-2016, 05:37 PM
MikeyTwins
MikeyTwins's Avatar
Ugh... wish this was closer! Are there any reputable tuners anywhere near you?
Old 08-22-2016, 01:46 AM
2turboc6
2turboc6's Avatar
Yes there is a couple
Old 08-22-2016, 01:47 AM
2turboc6
2turboc6's Avatar
bump for price drop
Old 08-31-2016, 05:10 PM
2turboc6
2turboc6's Avatar
Price reduced to $30k, need the car gone asap because in need of money.
To F/S Custom Twin Turbo C6
Old 09-01-2016, 12:42 PM
RichardCranium
RichardCranium's Avatar
any offers?
$15k.
Old 09-01-2016, 10:03 PM
boosted05
boosted05's Avatar
Ill trade you my 600hp supercharged c6
Old 09-06-2016, 12:30 AM
2turboc6
2turboc6's Avatar
sorry looking to sell no trades.
Quick Reply: F/S Custom Twin Turbo C6
