NA cam + Blower - Will this combo work
Well, Since I dont want to go through the process of buying and re-installing a blower cam on my car, at least for the time being.
So, im wondering if say an LG X3 cam or a QM600 would work with a Centrifugal SC. I understand its not the best option, but will the combo make more power than using the stock cam?
For the best deal I've seen buy an A&A kit during Andys 4 hour sale monday, You'll be glad you did.
I'm not sure what the specs are on those particular cams (I believe the X3 is a pretty big stick isn't it?) but if they are high in valve overlap, they're going to be counterproductive on a boost car. Overlap costs you boost by allowing pressurized air to escape out the exhaust valves while the intake valves are still allowing it to enter the combustion chambers.
Has anyone ever proved the "lot's" of overlap doesn't work?
Well I'd like to "disprove it"
Here's a cam with over 80 degrees of overlap, 238/248 on a 112
Notice this graph only goes up to 5500 rpm-just image the numbers at 6500. Now look at the torque-this a 402 and through a auto on pump gas. This is with a tiny little F1A blower amking 17 psi at 6800 rpm. Look at the torque at 3000, 3500 and 4000 and look up other dyno graphs of centri blowers-compare the torque?
Here is a cam-very similar to a G5X2(232/240)-stock short-12psi-I guess it doesn't make much power either? BTW-this is with LS1 heads and a LS1 intake.
Here's another car, he has an aggressive N/A cam-only 12 inches of vacuum at idle, he was told he won't make anypower with a blower with that cam. This is a A&A kit, stock short 8 psi, no meth. This thing will pick up 50 rwhp and 50 rwtq when he ups the boost!
There must be alot money being made in "blower cam" market-man it's too bad I don't buy into it.
I'm running a reverse split 232/228 114 LSA with my P1SC Procharger. Everyone told me not to do it because it's a "turbo cam." I think I'm in good shape with only 7 psi.
The other two cars make good power too, but I would like to see back to back results with the N/A cams vs. purpose-ground FI cams....I think there's power left on the table...
The physics of it seem irrefutable to me. A boost leak somewhere in the intake tract is going to cost you power isn't it? what's a big overlap cam other than a boost leak right in the combustion chamber?
I'm sure you have a bunch more experience with FI than I do, so don't take this to be argumentative...I just like conversations that might teach me something.
I didn't say a big cam with lots of overlap wouldn't make any power...I just said it wasn't the best choice for a blower car. I'm not at all surprised an F1A (most people don't consider that a "tiny little" blower ) huffing 17 pounds makes a train load of power with ANY cam...that's a pretty beastly combination.
F1A, is a tiny blower-it's the same size physically as a D1SC-hold it next to a YSi or Novi 2000.
Take the first graph, it's a F1A, it's a 402, it's got AFR heads but it' still breathing through a LS6 intake and stock 75mm TB-compare that graph at each point to some of the "other" big power blower graphs with "blower cams" and see how they compare-don't forget this is through a auto as well.
Received 1,194 Likes
St. Jude Donor '15
Dudeeee
As long as you like the operating characteristics of the cam, go for it. So, you can make 700 hp with a rowdy n/a cam at 10 psi or change to a milder/better mannered boost cam, and make the same power with a little more boost with no other changes. Whatever blows your dress up...your choice.
The whole big cam thing is a big Mith. I made 837whp 6psi with the LG7XX cam which has 40* overlap BTW same setup with headers made 623 all motor.
