Ls2 block question
08-02-2009, 06:09 PM
Ls2 block question
With a callies magnum xs 4" stroke crank dryers 300m rods and mahle pistons and steel main girdle how much boost can the factory block handle ?
08-02-2009, 06:53 PM
Former Vendor
The block can handle as much boost as the 4 bolt per cylinder heads can handle. Meaning, you'll push out a head gasket first. Bob
08-02-2009, 08:23 PM
At what point to head gaskets become an issue ? I plan on using studs and aftermarket heads although i havent decided which ones yet
08-02-2009, 09:56 PM
IMO if you are asking about the LS2 block and boost, your on your way to a Warhawk or LSX
08-04-2009, 05:28 AM
Former Vendor
Quote:
Originally Posted by
hucktyson
Normally around 20 psi of boost or so. You'll want heads with thick decks such as the ones from AFR. Check out this build where we used a new LS2 block.
http://www.exoticperformanceplus.com...Car.php?car=29 Bob
