C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
How does one use DashLogic?
Old 01-22-2015, 11:55 PM
NYOverlord
NYOverlord's Avatar
Default How does one use DashLogic?
Does anyone actually know how to use Dashlogic? Admittedly, the tuner who installed the bung, daisy chained the PLX wide band Air/Fuel sensor module, PLX vacuum/boost sensor and DashLogic couldn't explain to me how to use the DashLogic. I don't see any proper instructions other than the few sentences on a small card inside the box. And the manufacturer of Dashlogic doesn't even offer their phone number. Nor do they return emails. (Great customer support Palmer Performance Engineering!!!).
I figured out how to cycle/flip through the 8 pages of info. However, when I get to vacuum/boost, it shows -9 PSI. And it shows that whether I'm just cruising or at wide open throttle. -What gives?
I'd love to know how to make it show my 0-60 times and 1/4 ,mile times, but at this point, I'd be happy just to be shown how to monitor my Air/Fuel Ratio and current boost levels!!!
Can ANYONE help me?????
Old 01-23-2015, 12:03 AM
schpenxel
schpenxel's Avatar
Received 1,194 Likes on 1,053 Posts
St. Jude Donor '15
Config guide:
http://www.palmerperformance.com/dow...tion_Guide.pdf
Software for editing the settings on it:
http://www.palmerperformance.com/download/dashlogic.exe
You need to connect the unit to a computer, run the program I gave a link to, and see what PID it's actually trying to pull when showing "boost". There is a switch on the unit itself that you have to set to "config" before it will connect to a computer properly.
Does your car have a MAP sensor capable of reading boost?
Do the other parameters show up correctly?
I would be pretty scared of someone installing all that that didn't know how to configure dash logic. It is really simple
Old 01-23-2015, 10:47 AM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
As said in the other thread, just use the config utility to enter the correct formulas, and then set it up to display whatever you want. Can't really explain it more than that, it is super super simple. Making this post on the forum is harder than setting up a dashlogic.
Old 01-23-2015, 12:11 PM
NYOverlord
NYOverlord's Avatar
Originally Posted by schpenxel
Config guide:
Yes, I have a 3 bar MAP sensor/boost-vacuum sensor as well as an Air/Fuel Ratio sensor module and both are made by PLX, which are compatable with DashLogic.
I'm not good with computers, but I can try to get a hold of a friend's lap top and plug it in and check out what you are referring to. I wish I knew of a place in NY that is familiar with this stuff so I could bring my car there.
Thanks for the advice guys!
Old 01-23-2015, 12:13 PM
schpenxel
schpenxel's Avatar
St. Jude Donor '15
Like unreal said.. the PLX boost sensor was a waste. You can use a GM boost capable MAP sensor in place of the one the car normally uses and take readings off of that through the car's computer.. no need for a second one. You may already have one actually, I don't know.
Regardless.. if you can plug it in I'm sure someone around here will try to help. If you were local I'd fix it for you.
Doesn't have to or need to be on a laptop
Old 01-23-2015, 12:17 PM
Unreal
Unreal's Avatar
Just unplug it and bring it in and do it on the computer you are posting on.
It is preconfigured to read boost off the cars map, which is why the boost isn't working. You need to swap that to the PLX sensor, and program the transfer curve which is just typing in the equation PLX provides.
Old 01-23-2015, 12:21 PM
schpenxel
schpenxel's Avatar
St. Jude Donor '15
He was saying it was showing -9psi no matter what he did, so that kind of sounded like something was off to me.
Old 01-23-2015, 03:37 PM
Unreal
Unreal's Avatar
Probably has the wrong PID selected.
Old 02-23-2015, 07:49 AM
Seadawg
Seadawg's Avatar
I just got a dashlogic, and I plan to s/c my LS3 later this spring, so I want to replace my MAP sensor. Is this the sensor I need? "ACDelco 213-4681 GM Original Equipment Multi-Purpose Pressure Sensor"
Old 02-23-2015, 08:13 AM
schpenxel
schpenxel's Avatar
St. Jude Donor '15
What year is your car first?
And how much boost are you planning on running?
GM part number 12592525 looks like the stock ZR1 sensor to me so I'd take a look at that one. I'll look up the one you posted though and see if it's the same.
I think either will work fine on a newer car.. my concern was that the older computers (2005 specifically) are very limited in what sensors the computer will accept.. so for a 2005 you either have to buy a sensor from DPE or build one
Old 02-23-2015, 11:23 AM
Unreal
Unreal's Avatar
He said ls3 car so 08+ which should have no issues with a zr1 map.
Old 02-23-2015, 11:37 AM
schpenxel
schpenxel's Avatar
St. Jude Donor '15
Good point. Missed that.
Old 02-24-2015, 09:57 AM
Seadawg
Seadawg's Avatar
Thanks for the info, and the part number I gave was "supposed" to supercede the original C6 ZR1 sensor
Mine is a 2011 Grand Sport, MN6, dry sump. I want it to continue to be daily driver and reliable, so I never anticipate being over 600 rwhp. I'll be going with a centrifugal blower, sorry I don't know what boost level to expect.
I'm also having fun learning all of the parameters that the Dashlogic will allow you to monitor. And learning the "normal" ranges for them.
Old 02-24-2015, 10:09 AM
schpenxel
schpenxel's Avatar
St. Jude Donor '15
Gotcha
Yeah that sensor should work fine. The cars computer does have to be reprogrammed to know how to use that sensor as well. You probably knew that, but just wanted to make sure. Will take 3 minutes or less for anyone with HP Tuners / EFI Live
Old 03-01-2015, 11:39 AM
adidasUNT8
adidasUNT8's Avatar
I am getting blown now...
Will the ZR1 MAP sensor work with my 06 c6z ECU?
Old 03-01-2015, 08:26 PM
Unreal
Unreal's Avatar
Nope, need the DSX, or DPE sensor. Or swap to 09+ ecu.
silver_viper_tb (01-08-2017)
Old 03-01-2015, 08:32 PM
schpenxel
schpenxel's Avatar
St. Jude Donor '15
Or order sensor MPXA4250AC6U from Digikey for $16, chop up an old MAP sensor housing you got off eBay for $12 and make it work
https://www.corvetteforum.com/forums...post1588414424
To How does one use DashLogic?
Old 03-04-2015, 09:50 PM
CurtMo
Cruising
CurtMo's Avatar
I just ordered the DashLogic today, and was wondering if there was any way to connect it to my aftermarket head-unit?
Couldn't find my answer on their website, hoping you guys could help me out
Old 03-04-2015, 09:55 PM
schpenxel
schpenxel's Avatar
St. Jude Donor '15
No, there isn't a way to do that
Old 04-07-2015, 04:34 PM
bdickey058
bdickey058's Avatar
i'm looking into buying one of these. I have Hp Tuners and already have a a/f gauge and boost gauge but i would i like the looks of this unit. With Hp Tuners can i turn on the perameter. I suck with technology so any help would be appreciated.
Quick Reply: How does one use DashLogic?
