Rear mount turbo build
#125
Im trying to decide what intercooler to get on my rear mount. I'm not sure if I should get the treadstone passenger or driver outlet. I've seen the cold side ran both ways. Is there a reason you ran it to the drivers side vs. the passenger?
#128
Ran drivers side due to my turbo placement. Hot side needed to be passenger side
#129
I guess that makes enough sense. I have a better question then. If you flipped the turbo around (if it was even possible?) do you think you'd of had more clearance to run the cold side, through the passenger side, and not had to of crushed the pipe?
#130
If you run it on the drivers side and have patience you can run it next to the motor and through the subframe and sway bar.
#131
Thanks for the answers.
#132
Cool man excited to see how those oil less turbos work. Going to be nice not having a scavenger setup
#133
#134
you can also run the pipes up through the engine bay and back down to the cooler, it's what I plan to do as my car is already very low so I don't wanna loss any more ground clearance. Here is Danz build where he did his like this. https://www.corvetteforum.com/forums...unt-c5z06.html
#135
#136
For example your ic drops temps 30 degrees. Id rather have 30 degrees taken off 130 than 170 degrees.
#137
Not really true at all unless you're spraying meth. The whole idea of the cold side piping is to keep it away from heat. An air to air can only do so much. I never said it wouldn't make power or spool (smaller turbo better spool fast). It's just not very efficient to run your cold side piping near a hot source right before an ic.
#138
#139
I don't want to get into a pissing match with you but that's not how air to air intercoolers work, not to mention the pre-intercooler temperature of the air is going to be higher than the engine bay temperature to begin with. For clarification if you care you can look up a generic temperature profile for a cross flow heat exchanger. To run the pipe or not that is up to you, just wanted to clarify that little bit on the heat being a concern.
#140
Its funny because I think the most important part of this setup is actually retaining heat on the hot side and not so much trying to cool the charge air. These rear mounts bring some new questions to the table.
