What kind of boost levels are you guys getting with your supercharger setups & puleys
Im installing an A&A SC Kit T1-V2 in my 2009 Z06 with a 4" blower pulley. I had a 10% underdrive ATI from when it was N/A but opted to go with the 10%overdrive after some fellow member inputs. I got a really good deal on a 3.8 pulley from another member which i purchased as well but Im hesitating on weather to put it on now or build it together first with the 4" and 10% overdrive. Just trying to save on time and tune money if I can. I have contemplated the Idea of going with a 3.4 Blower pulley and putting a Tial 38mm Waste gate on the charge pipe to control with a boost controler but I dont really see the need for that if I can dial in close to my goals with the 4" pulley
My goals are to get to 700 rwhp + no less. Car is now making 570 rwhp LSX heads cnc ported by WCCH
EPS cam 228/244 .639/.639 115 LSA +4 advance
11.0:1 comp.
Full headers no cats B&B Fusion 3" exhaust
tune.
any experience you guys have or ideas would be greatly appreciated.
Thanks!
RoB
11.0:1 comp.
tune.
Thanks!
RoB
thats the feedback im getting, especially with the 10% overdrive main pulley. Usually others have had to go down to 3.8 or even 3.6 with stock dampner.
Ill see how close i come with the 4" and just bolt it up like that for now.
each one of these belts is 26 bucks!
11.3 psi with a stock LS3 balanced (for now) and 4.25 blower pulley. Don't worry about boost though. The more power it makes on the least amount of boost is what I like.
That's cheap, start breaking 10 rib or cog belts. If unsure the belt size, just buy 3 or 4 and return the ones that don't fit.
I've probably gone through $500+ in belts with my car. If you are complaining about $26 for a belt, a blower may not be for you.
You running 6 or 8 rib? I can send you some 8 rib pullies if you are 8 rib.
I made ~6psi with 3.8 upper stock lower, but had a 228/232 cam and good heads. Heads/cam/headers/etc will all effect boost since it is just measurement of restriction. A 10% lower 4" upper should be enough to see ~680-700rwhp. What boost that is at, who cares, it doesn't matter.
forged bottom end?
my setup with D1SC on a stroked ls2 and ported ls6 heads and mild blower cam made ~700whp with 4.25 pulley and about 9.5psi, moved it down to a 3.9" and made 760whp at 12.5psi. This is all on 8 rib with 10% larger IW crank pulley but the motor was only 9.5:1 compression. New setup going to try it with 3.55" blower pulley.....
I vote 4" pulley and do what you have to in order to put a good 4" intake on there.
Stock bottom end for now, stock fuel system too with a BAP. I figure 700hp should be a good shooting point without having to go into forging the bottom end or having to modify fuel system
Hey I hope u make your goal with your setup , I'd be concerned about my compression & my bottom end if I'm stock , 700 to the tires , I don't doubt it will make It , but for how long ?
I maxed out the Ti on my 377 with a 3.47/8.0 pulley combo and shift it at 6500. That is right around 13 psi on my motor
Got boost
My set up is similar . I run a Ti/1500 blower out the box blower kit , Lsx heads , eps cam ect... on my Z . 700 rwhp will be easy to attain . Plenty of 800 rwhp Zs on this board with no issues . I ran the .639 eps cam in my g/s . It makes great power . I think pat g runs a cam very close to that as well in his g/s and he makes 800 in his g/s .
