200 shot on a ls2?
I think it's a good idea! I'm doing a 2 stage setup that is gonna be 225 total on a bolt on LS2 with stock internals. I haven't had time to dyno or tune it since I ended up getting busy with work. I ready to try it out soon as I can.
I have read the heat from the 200 shot killed these motors on pump gas but with ethanol ot burns colder then pump gas there for I kinda think she would live longer, it's tuned on a 150 now makes 560hp on a mustang dyno going back to finish it thus week with higher ethanol
Former Vendor
Make sure you have enough fuel pump to run a 200shot on E85. I also suggest using a progressive controller to prevent an initial lean spike. Also, I hope you're using a good nitrous plug and gap already?
Have fun with it! Let us know how you make out at the track or dyno.
-Shane
C5-Fan (12-24-2017)
lots of people do the exturnal tank and spray race gas in with biger shots but i didnt want to do it that way
i should have plenty of fuel id1000cc and a 450 pump that i just switched ,im thinking of getting a tune for the 200 and just saving the map and just switch if i have to ,do a good bit of racing on the street and track so some times i need to race some fast cars lol ,deff will keep posted of track and dyno ,going back to finish up the 150 shot and hoe to make more then 560 on a mustang dyno
Former Vendor
-Shane
I finally got it on the dyno and sprayed for the 1st time Friday. The tuner recommended I don't go above 150 since its mostly just a street cruiser now. He said he could set it up if I really wanted it but he said this way I'm pretty safe and don't have to worry about anything. Anyway on to the #s which is what you car about haha.
Its just a bolt on LS2, I put down 365 with the stall unlocked and 526 with a 150 shot.
I'm out of town so he's supposed to send me video and dyno info soon. I'm ready to see what it will do on the track!
hope you get it to hold together
I never got a gd et on spray being my first nitrous car an I was nervous to launch it but I did end up taping 136 but the car had fuel surging because the nitrous was being pulled off the oem rails an I feel that the car would have trapped even a high 140.the car has been 11.0 at 125 just on motor .it should be fine with the shot I did a fuel cell and rails an changed the controller to a progressive so it will take the hard hit off of if
