C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Finally, done?
Old Sep 26, 2015 | 06:29 PM
RicardoFors68's Avatar
RicardoFors68
Default Finally, done?
Got the car back yesterday, been eaining so not a chance to test drive
Final numbers were 542/496. Seems a little under, but considering it's a stock bottom and stock drivetrain, I should very happy....
Old Sep 26, 2015 | 06:49 PM
WA 2 FST's Avatar
WA 2 FST
It's all about putting the power to the ground with a _real_ street car that you enjoy day-to-day. You'll enjoy the new power it is making and it will put a smile on your face.
Old Sep 26, 2015 | 07:56 PM
RicardoFors68
Yes, definitely
Old Sep 28, 2015 | 11:03 AM
RicardoFors68
Pic of dyno sheet coming shortly, was told that its making 7psi, 15degs at max hp. Tuned used speed density told to maybe upgrade to LS7 maf or get a stand alone iat if I wanted to get rid of stock maf. Driving around town in 203deg coolant temp. Was told this is to be expected since there's a chunk of aluminum partially vlocking the radiator.
Was told that next step would be a cam, hp wise. Drivetrain improvements as higher tq stall, maybe taller gears. 1 7/8 headers.
Old Sep 28, 2015 | 11:07 AM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
Meth?
Old Sep 28, 2015 | 11:43 AM
RicardoFors68
Originally Posted by schpenxel
Meth?
Yes
Old Sep 28, 2015 | 12:21 PM
croatbob's Avatar
croatbob
542 on ls7 with meth?? what blower? thats sounds horribly under!
Old Sep 28, 2015 | 12:27 PM
RicardoFors68
V3 s trim with 3.6 pulley on LS2....
Old Sep 28, 2015 | 01:03 PM
Pitufina's Avatar
Pitufina
Everything else is bone stock? 7psi with a 3.6 pulley sounds low to me. Did you do the install? I would check for leaks or for belt slip.
I don't know but maybe is just me who thinks that way.
Old Sep 28, 2015 | 01:51 PM
RicardoFors68
Stock everything! No had a shop do the install. They said every safe hp has been squeezed before it compromises stock components in enfine and transmission.
Old Sep 28, 2015 | 03:11 PM
croatbob's Avatar
croatbob
if you hear a tuner say "safe tune" on a basic setup, that generally means it didnt make the hp we were hoping. something definately up with the setup and/or tune
Old Sep 28, 2015 | 03:22 PM
RicardoFors68
To be absolutely fair, he asked me to choose from, power, cheap, or reliability and I chose reliability. So I'm thinking that influenced his approach
Old Sep 28, 2015 | 04:01 PM
ajrothm's Avatar
ajrothm
542rwhp on 7psi is not bad at all for a bone stock Ls2. Especially thru an auto. (Assuming stock exhaust manifolds and exhaust).
Headers/X-pipe and another couple psi would break 600rwhp with the stock cam still in it. That is the perfect combo for driveability/power.
Old Sep 28, 2015 | 04:09 PM
Arctic Vette's Avatar
Arctic Vette
Congratz n enjoy!
Old Sep 28, 2015 | 04:20 PM
RicardoFors68
I do have SLP headers and x pipe.... I think I'm another tune away to be really close to 600 and still have a reliable engine. But for now I'll concentrate in learning how to drive the car as is, probably get ready to replace the current Nittos pretty soon
Old Sep 28, 2015 | 09:11 PM
C U IN REARVEIW's Avatar
C U IN REARVEIW
Nope....I have ls2,a&a ti trim blower w/4" pulley (7psi) making 585whp.I have meth only for safety/cooling (no additional timing added for it)
Old Sep 28, 2015 | 09:18 PM
GeneSch's Avatar
GeneSch
I would say he gave you what you asked for, safe...
I asked for the same on my first tune, Ls7 and it made 580 on a mustang dyno with 4lbs
after adding meth and some boost we are at 665 on 7 lbs., let off at 6,300Rpm.
You should be able time find more in there when you are ready.
To Finally, done?
Old Sep 28, 2015 | 09:20 PM
RicardoFors68
I honestly thought I would be around your numbers, maybe 40hp difference is not that noticeable
Old Sep 28, 2015 | 10:19 PM
highrolrcustoms's Avatar
highrolrcustoms
It seems that different tuners have different meanings of safe tunes. From what I have seen at East Coast Supercharging most of their LS2 with meth are 650+ on safe tune. RPM in garner NC had a c6 LS2 put down 821rwhp on a ECS kit, meth,..etc on stock bottom end
Old Sep 28, 2015 | 10:33 PM
RicardoFors68
This as a consumer and car enthusiast makes you wonder, this is a big gap in numbers. Most LS2 I see over 600 have swapped ca s at least.
That's why people say to pick and choose a tuner wisely....
