T6060 ratios for a Supercharged LS3? Z06 or ZR1?
LS3, forged bottom, cam, headers, ported heads, Vortec V3 (for now-YSI in the future possibly). Guessing 600-650 whp. I want to upgrade to a T6060 since the stock T56 has some high miles on it. Was thinking the ZR1 ratios would help it hookup better off the line, but I know the ZR1 probably has huge torque/power at low rpm due to roots style s/c. Would the centrifugal s/c not pull the taller first gear? Staying with 3.42 rear gear 26" tire.
Just a street car... messing around light to light and roll ons. Maybe a hpde someday.
This is in a C5 - but most of driveline is now C6..
Any thoughts or comments?
I would use Z06 for 1-4 and a ZR1 5th gear. I already have a TR6060 but in Z51 ratios which are too steep for the power I'm making. If/when I hurt the trans I will be doing what I said above with an RPM TR6060.
The Z51 T6060 has the old LS6 gearing correct? Tire smoker 1st gear.. ?
2.66 is better all around for what YOU want to do.
If you were not blown, and NA wanting to do HPDEs, the 2.29 would be better.
The Z51 is out, the ratios just suck. 3rd too tall for 60 rolls, 2nd to short.
The 2.29 has you shifting a lot, and while that doesnt sound bad, it gets annoying. The ratios rock, but the super short 6th gear will reduce mpg significantly.
The MM6 T56 I have now has the 2.66 ratio. With the stock LS1 and supercharger 517whp it was barely hooking with Nitto 05R's. Should have 100hp more with new combo and I think traction will be an issue. Was thinking 2.29 might help keep it hooked up better through 1st. and the close ratio 2-5th gear would be a benefit to really keep rpm's in the boost??
I do agree 6th gear on the ZR1 trans for me would not be a good thing. It would be better to have the Z06 6th to keep highway rpm's down. But that could be changed at a later date.
My vette is not a daily driver. Play toy/fun toy..
I really like the ZR1 box, Ive had several. ( Its the 229 you listed, for those that dont know)
Pros- Shift extension is short, 1100-800 rpm drops due to the Close ratio. Always a right gear for the occasion.
Cons- Lots of shifting. High RPM cruising. Tall first gear (Pro or con) Taller over all 1-3, same 4th, shorter 5th, shorter 6th.
Received 2,276 Likes
C4 of Year Winner (performance mods) 2019
One more vote for NOT using the Z51/GS/C5Z ratios. I like those ratios for NA, but once I put the blower on my GS I very quickly realized that don't work as well for that setup. Personally if I ever switch, it will be to ZR1/2.29 ratios. I didn't buy the car for the gas mileage, and a lot of time now, I currently run in 5th anyway.
Not sure if the T56 Z51 ratios are similar to the 6060 Z51 but my T56 Z51 ratios sucked. In the 1/4 mile first and second were run out very quickly. And 5th was a huge drop. Looking forward to what I'll do in the 1/4 with my '08 Z06 ratio 6060.
Yes, they are the same ratios. I think they work ok stock, but once I added the blower, 1st became useless and 2nd isn't much better. From a dig I'd probably be better off just starting in 2nd as it's 2.07 which is closer to the ZR1 1st of 2.29.
I have a t56 with c6 z06 ratios in it now and when i got to tr6060 i'll go with Zr1 ratios for sure. The box i have now works great but 1/2 gear are shorter than I wish and who cares about 5/6 imo
Received 1,194 Likes
St. Jude Donor '15
1/2 are short in mine too. 05 Z51
While I originally wanted the 0.50 6th, I actually liked the shorter ZR1 6th gear. I'm sure it cost me some fuel economy on the highway, but it made the car a lot more lively when cruising in top gear with my cam/centri combo. I really didn't build the car for gas mileage, and it wasn't a daily driver. In the end, I think it was a good choice. The ZR1 5th gear was great for the 1/2 mile events at my power level, and I think the close 5-6 ratios would have worked well for higher speed events. Those gears are really close with the ZR1 gearset.
If I ever hurt the trans in my GS, I'd probably do the same thing again. Like everyone else has said, the Z51 ratios pretty much suck. But seeing as how I already have the 30-spline main shaft from the factory in this car, that probably won't happen.
Hope that helps.
